bbryson_2000 Posted February 25, 2016 Posted February 25, 2016 I need a lisp routine that will draw a pline with a defined width of 1/32". User to give a start point and an end point. Thanks .......JerryB Quote
marko_ribar Posted February 25, 2016 Posted February 25, 2016 Use PLINEWID sysvar and when set correct width 1/32'' continue to draw pline with standard PLINE command... Quote
Lee Mac Posted February 25, 2016 Posted February 25, 2016 (defun c:mypline ( / plw ) (setq plw (getvar 'plinewid)) (setvar 'plinewid 0.03125) (vl-cmdf "_.pline") (while (= 1 (logand 1 (getvar 'cmdactive))) (vl-cmdf "\\")) (setvar 'plinewid plw) (princ) ) Quote
bbryson_2000 Posted February 25, 2016 Author Posted February 25, 2016 That was quick... Thank you very much... I will try this later today. Jerry Quote
BIGAL Posted February 26, 2016 Posted February 26, 2016 Simple and to the point as usual Lee a thought referring to the error trapping reactor posted previously by me, the user would type p132 on command line ie pline 1/32 wide p18 1/8 so no hard coding of width. Watch this space. Quote
BIGAL Posted February 26, 2016 Posted February 26, 2016 Have a go at this you will need to do P0-03125 for a 1/32 width 2nd version could do p132 ; Enter the filet radius as part of a command line entry f100, offset O234, circle c123-45, P123 for pline width ; note - is used for decimal point ; original code and methology by Alan H ; assistance and code that worked by Lee-Mac ; OCT 2015 ( (lambda nil (vl-load-com) (foreach obj (cdar (vlr-reactors :vlr-command-reactor)) (if (= "fillet-reactor" (vlr-data obj)) (vlr-remove obj) ) ) (vlr-command-reactor "fillet-reactor" '((:vlr-unknowncommand . fillet-reactor-callback))) ) ) (defun plwid ( / width oldwidth) (setq width (distof (substr com 2) 2)) (setq oldwidth (getvar 'plinewid)) (if (<= 0.0 width) (progn (setvar 'plinewid width ) (vla-sendcommand fillet-reactor-acdoc "_.pline ") (setvar 'plinewid oldwidth) ) ) ) (defun filletrad ( / rad) (setq rad (distof (substr com 2) 2)) (if (<= 0.0 rad) (progn (setvar 'filletrad rad) (vla-sendcommand fillet-reactor-acdoc "_.fillet ") ) ) ) (defun makecirc ( / rad) (setq rad (distof (substr com 2) 2)) (if (<= 0.0 rad) (progn (setvar 'circlerad rad) (vla-sendcommand fillet-reactor-acdoc "_.Circle ") ) ) ) (defun offdist ( / dist) (setq dist (distof (substr com 2) 2)) (if (<= 0.0 dist) (progn (setvar 'offsetdist dist) (vla-sendcommand fillet-reactor-acdoc "_.Offset ") ) ) ) (defun fillet-reactor-callback ( obj com ) (setq com (vl-string-translate "-" "." (strcase (car com)))) (cond ( (and (wcmatch com "~*[~F.0-9]*") (wcmatch com "F*") (wcmatch com "~F*F*") (wcmatch com "~*.*.*") ) ; and (filletrad) ) ( (and (wcmatch com "~*[~C.0-9]*") (wcmatch com "C*") (wcmatch com "~C*C*") (wcmatch com "~*.*.*") ) ;and (makecirc) ) ( (and (wcmatch com "~*[~O.0-9]*") (wcmatch com "O*") (wcmatch com "~O*O*") (wcmatch com "~*.*.*") ) ; and (offdist) ) ( (and (wcmatch com "~*[~P.0-9]*") (wcmatch com "P*") (wcmatch com "~P*P*") (wcmatch com "~*.*.*") ) ; and (plwid) ) ) ; master cond ) ; defun (princ) (or fillet-reactor-acdoc (setq fillet-reactor-acdoc (vla-get-activedocument (vlax-get-acad-object))) ) (princ) ; next Point or option keyword required. Quote
