jbreard Posted March 6, 2016 Posted March 6, 2016 Hello, I'm having issues when trying to find the intersection between two lwpolylines using the following code : (vl-load-com) (defun c:intersect (/ curve1-ename curve2-ename curve1-obj curve2-obj c d) (setq curve1-ename (car (entsel "\nSelect first curve"))) (setq curve2-ename (car (entsel "\nSelect second curve"))) (setq curve1-obj (vlax-ename->vla-object curve1-ename)) (setq curve2-obj (vlax-ename->vla-object curve2-ename)) (setq c (vlax-variant-value (vlax-invoke-method curve1-obj "IntersectWith" curve2-obj acExtendnone ) ) ) (setq d (vl-catch-all-apply 'vlax-safearray->list (list c) ) ) (entmakex (list (cons 0 "POINT") (cons 8 "00-CONSTR7") (cons 10 (list (car d) (cadr d))) ) ) (princ) ) All my lwpolylines have an elevation of 0 so this is not the issue. In the attached file, you will see small polyline in a blue revision cloud that apparently do not intersect the white polyline on layer "AXE-REF-PK" (but they obviously do ; an error of the type : "ActiveX Server returned an error : invalid index" is generated). This polyline has 1900+ vertexes so maybe there is a limitation that comes with the size. I have drawn above the exact same situation but with a poyline with half the vertexes. This time, the program finds an intersection everytime. There sure are many things I don't get with the intersectwith method Does someone has ever encounter a similar problem ? Regards, Jacques Intersectwith Method Issue.dwg Quote
Lee Mac Posted March 6, 2016 Posted March 6, 2016 The intersectwith method can be temperamental if the objects are far from the origin - try the following code instead: (defun c:inters ( / lst ob1 ob2 vec ) (if (and (setq ob1 (car (entsel "\nSelect 1st curve: "))) (setq ob2 (car (entsel "\nSelect 2nd curve: "))) (setq ob1 (vlax-ename->vla-object ob1)) (setq ob2 (vlax-ename->vla-object ob2)) ) (if (or (setq lst (group3 (vlax-invoke ob1 'intersectwith ob2 acextendnone))) ( (lambda ( vec / ob3 ob4 ) (vla-move (setq ob3 (vla-copy ob1)) (vlax-3D-point vec) (vlax-3D-point 0 0)) (vla-move (setq ob4 (vla-copy ob2)) (vlax-3D-point vec) (vlax-3D-point 0 0)) (setq lst (group3 (vlax-invoke ob3 'intersectwith ob4 acextendnone)) lst (mapcar '(lambda ( x ) (mapcar '+ x vec)) lst) ) (vla-delete ob3) (vla-delete ob4) lst ) (vlax-curve-getstartpoint ob1) ) ) (foreach pnt lst (entmake (list '(0 . "POINT") '(8 . "00-CONSTR7") (cons 10 pnt)))) (princ "\nNo intersection detected.") ) ) (princ) ) (defun group3 ( lst / rtn ) (repeat (/ (length lst) 3) (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn) lst (cdddr lst) ) ) (reverse rtn) ) (vl-load-com) (princ) Also, I would advise against defining intersect as a custom command, as this is already a built-in AutoCAD command. Quote
jbreard Posted March 6, 2016 Author Posted March 6, 2016 Thanks a lot Lee Mac ! Works like a charm. I will keep in mind that AutoCAD can have problems with typical geographical coordinates values. As for the intersect built-in command, I was not trying to emulate it. I actually need to be able to find the intersection between two polylines inside a larger lisp programm and your method does the job perfectly. And I managed to set eyes on news commands like vla-move ! Thanks again and best regards, Jacques Quote
Lee Mac Posted March 6, 2016 Posted March 6, 2016 You're welcome! - I'm glad the function is now performing well. I'm aware that you were not trying to emulate the built-in AutoCAD command, but you should refrain from using the names of built-in commands as AutoLISP custom commands. Quote
jbreard Posted March 7, 2016 Author Posted March 7, 2016 Ah ok. I understand now the true meaning of your comment. I will not do it in the future ! Thanks again. Jacques Quote
