sanju2323 Posted March 14, 2016 Posted March 14, 2016 (edited) Hello Everyone, I am trying to column "A" where text "TP" is just the place to circle should fall. And the remaining other "code" should fall point. Thank you in advance. Edited March 16, 2016 by sanju2323 Quote
BIGAL Posted March 15, 2016 Posted March 15, 2016 Just look up how to use concatenate and IF in excel, just copy one column say "J" straight to autocad and all done. There are numerous examples here, serach excel. Quote
sanju2323 Posted March 15, 2016 Author Posted March 15, 2016 BIGAL, Thank you for the suggestion, I know it's possible from using concatenate and if formula, but I want to directly plot circle using vba. I do not want any extra column. sanju Quote
BIGAL Posted March 16, 2016 Posted March 16, 2016 Thats the easy way. Ok get a copy of getexel.lsp this is a good example of how to do Autocad excel, you can read and write cells then do what you want you should be able to convert to VBA but why bother, check the samples. Quote
BIGAL Posted March 17, 2016 Posted March 17, 2016 A second way maybe easier export as a CSV and just read line by line use a IF or Cond to check the "A" cloumn code and use the x&y co-ords pretty easy. In lisp or vba. (cond ((= type "TP")(do_circle)) ((= type "CP")(do_point)) ((= type "FE")(do_INS_FE)) ) Quote
sanju2323 Posted March 18, 2016 Author Posted March 18, 2016 BIGAL, yes this code is very useful, Thank so much sanju Quote
