Results 1 to 4 of 4
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    Question AutoCAD MEP - auto enable property sets?
    Is there an option to always include some or all Property Sets to the AEC Objects as you are modeling them? Thanks in advance.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Full Member
    KeithBrown's Computer Details
    Windows 10
    Need a minimum of 3 to work effectively!
    MEP 2016
    Jun 2012
    Chicago, IL, USA
    58
    Options->AEC Object Settings Tab. Then the AEC Property Set Definitions section in the lower left. Check to automatically attach all property sets to objects as they are inserted.
    DISCLAIMER: If the property set definition applies to an object it will always get attached to it. This could not always be the best scenario.
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    Thanks Keith. Do you have an example where it wouldn't be desired?
    Full Member
    Windows 10
    MEP 2016
    Jun 2012
    Chicago, IL, USA
    58
    The EastCoast software uses style based property sets to report data about the duct. They attach an override property set to a duct object if the user wants to override this data. Maybe not the best scenario but this is how it works. The override property sets should only be attached to a duct object if the style based properties have been overriden. You can see the problem. Auto attaching all property sets in all instances in this case causes an issue with reporting.
  1. Property sets, AEC spaces and tags
    By hertz hound in forum MEP
    Last Post: 14th Sep 2013, 12:31 pm
  2. Importing to Property Sets in Lisp.
    By sarah123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Aug 2013, 11:27 am
  3. Synchronizing wall and door property sets - Need help!
    By BrianClarke in forum AutoCAD General
    Last Post: 6th Apr 2011, 04:34 pm
  4. Property sets for styles in Acad Architecture
    By mickbradford in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Feb 2009, 10:09 am
  5. Property Sets and Schedules
    By ithink in forum AutoCAD General
    Last Post: 28th Sep 2007, 08:01 pm
