Dear Friends,
I am trying to develop a code, that should take the user input and then it should match to assigned list values, after it should give the output as an alert box.
Following is the code, I wrote. But not working. Please help me ..
(DEFUN C:LSTBRKER ()
(setq BRKLST (LIST
(LIST "SM" 6 16 32 64 100)
(LIST "MED" 125 160 200 250 315 400)
(LIST "HVY" 600 800 950 1000 1500 2000 3000)
(LIST "HY+" 3500 4500 5700 6200 8500))
(setq RQBLST (getstring "\n Please Enter the Required Breaker Catogories = "))
(SETQ REQCAP (STRCASE RQBLST))
(if (= (REQCAP) (assoc BRKLST LIST))
(Progn
(Princ (assoc BRKLST))
advanced thanks
Welcome to CADTutor.
Is this what you are after?
(defun c:test  (/ lst st f)
 (setq lst '(("SM" 6 16 32 64 100)
             ("MED" 125 160 200 250 315 400)
             ("HVY" 600 800 950 1000 1500 2000 3000)
             ("HY+" 3500 4500 5700 6200 8500))
 (if (and (/= ""
              (setq st
                     (getstring
                       "\n Please Enter the Required Breaker Catogories = ")))
          (setq f (assoc (strcase st) lst))
   (alert (vl-princ-to-string f))
I prefer ( getkword ) in these types of scenarios:
[b][color=BLACK]([/color][/b]defun c:lstbrker [b][color=FUCHSIA]([/color][/b]/ brklst input data[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq brklst '[b][color=NAVY]([/color][/b]
   [b][color=MAROON]([/color][/b][color=#2f4f4f]"SM"[/color] 6 16 32 64 100[b][color=MAROON])[/color][/b]
   [b][color=MAROON]([/color][/b][color=#2f4f4f]"MED"[/color] 125 160 200 250 315 400[b][color=MAROON])[/color][/b]
   [b][color=MAROON]([/color][/b][color=#2f4f4f]"HVY"[/color] 600 800 950 1000 1500 2000 3000[b][color=MAROON])[/color][/b]
   [b][color=MAROON]([/color][/b][color=#2f4f4f]"HY+"[/color] 3500 4500 5700 6200 8500[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]initget 1 [color=#2f4f4f]"Sm Med hVy Hy+"[/color][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq input [b][color=NAVY]([/color][/b]strcase [b][color=MAROON]([/color][/b]getkword [color=#2f4f4f]"\n Please Enter the Required Breaker Catogories - Sm/Med/hVy/Hy+ "[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq data [b][color=NAVY]([/color][/b]assoc input brklst[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]terpri[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1 data[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
-David
My prefrence now days is to use a list box function see lee-mac.com forces a correct pick only.
(LM:listbox "Please pick" '("SM" "MED" HVY" "HY+") 1)
Hi Thank you Very Much for your quick support and accurate reply......
Thank you very much Tharwat for quick reply.. and nice solution...
You are most welcome. :)
Hi David Bethel, Thank you very much for your valuable input, that's looking nice. Your option making the lisp code output great. it's also showing the required input... Great thing....Thanks once more..
LOL I guess that I'm more of a keyboarder rather than a mouser 8)
