Results 1 to 7 of 7
    Full Member
    AutoCAD 2014
    Sep 2015
    64
    Default Customizing the Ribbon
    (Using Autocad Architecture)
    I've seen that, using some profiles, the UI changes and some buttons disappear. I work mainly in the standard "Autocad" profile, but there are some buttons which it doesn't have; eg. the Add Stairs (STAIRADD) button, which I need.
    I've tried using the CUI to transfer it and couldn't find either the button or the command.
    How do I transfer it from the Architecture profile to regular Autocad profile?
    Thanks.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    I moved your thread to the Architecture & ADT Forum.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    Go into the cui in the Architecture profile and use the cui find the command and look at its properties ^c^c^p_Stairadd etc copy to notepad all the relevant bits command and icons. Create a dummy item in your other profile CUI and cut and paste the correct command etc and icons. Lynn Allen from www.cadalyst.com has a nice tutorial about changing the cui.
    I am using CIV3d but have commands from all over the place in my workspace, just cut and pasted.
    Full Member
    AutoCAD 2014
    Sep 2015
    64
    Quote Originally Posted by BIGAL View Post
    Create a dummy item in your other profile CUI...
    I'm a beginner at this so please tell me: is a dummy item a special item? or a regular item created in the usual way?
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    Just use any command as a start copied into the cui so its twice then edit that item to the command you want. You may need to exit and restart autocad.
    The link showing how to do it. http://www.cadalyst.com/management/t...-21-no-2-27271
  6. #6
    Full Member
    AutoCAD 2014
    Sep 2015
    64
    I made a new (duplicate) command and pasted in all the info from the original, and it works. Only problem is that it displays a question mark instead of an icon. What could have gone wrong? I inserted the exact icon identifier as in the original.
  7. #7
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    825
    Quote Originally Posted by rlcad View Post
    Each CUI has a dll file with icons. If you copied the command from a different CUI it may not have that icon in it's dll file. You may have to export it as a bitmap and use it for the new command. Keep in mind the Stairadd command will not work if Acad is the only CUI loaded because it's not a basic AutoCAD command.
  1. Customizing the Ribbon or Toolbars
    By dave78 in forum CAD Management
    Last Post: 18th Sep 2014, 04:32 am
  2. customizing the ribbon with smart actions
    By samifox in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 19th Feb 2013, 08:02 am
  3. Replies: 1
    Last Post: 20th Nov 2009, 12:05 am
  4. customizing
    By JONTHEPOPE in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jul 2008, 05:41 pm
  5. Matt Stein (aka Ribbon Man) on the AutoCAD 2009 Ribbon
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 7th Jun 2008, 03:20 am
