Happy Hobbit Posted April 30, 2016 Posted April 30, 2016 How can I vl-sort a list of dotted pairs by the first element of each [lowest first] For simplicity my list is similar to: (("1" . 1) ("A" . 1) ("C" . 2) ("3" . 1) ("B" . 5) ("D" . 2) ("2" . 3) ("E" . 5)) I've tried various (mapcar '(lambda functions but I cannot seem to get it right Anybody got a solution please? Quote
pBe Posted April 30, 2016 Posted April 30, 2016 The help file shows an example on vl-sort similar to your list, try and figure that out first, pretty sure you will come up with the answer (light bulb). Vl-sort on AutoDesk knowledge network Quote
Happy Hobbit Posted April 30, 2016 Author Posted April 30, 2016 (edited) *PING* Easy when you know how, isn't it? The variable holding my list is z All I needed was: (vl-sort z (function (lambda (a b) (< (car a) (car b))))) Must be half asleep still :-p Thank you for that pBe Edited April 30, 2016 by Happy Hobbit Forgot to thank Quote
pBe Posted April 30, 2016 Posted April 30, 2016 Excellent, now lets make it more challenging interesting for you. sort Z and come up with this result (("A" . 1) ("B" . 5) ("C" . 2) ("D" . 2) ("E" . 5)("1" . 1) ("2" . 3) ("3" . 1) ) Quote
Happy Hobbit Posted April 30, 2016 Author Posted April 30, 2016 Oh Lord! You nasty person you :-) The only way I can think of is some sort of numberp comparison function, but I bet there's another way....? Quote
pBe Posted April 30, 2016 Posted April 30, 2016 The only way I can think of is some sort of numberp comparison function, Go for it ...but I bet there's another way....? Pretty sure there is Quote
Happy Hobbit Posted April 30, 2016 Author Posted April 30, 2016 :surrender: I submit, c'mon tell me Quote
pBe Posted April 30, 2016 Posted April 30, 2016 :surrender: I submit, c'mon tell me You can do it, give it time, i honestly dont have the answer now , using mobile device to reply to this thread, but i have ideas. I bet there are others that has a solution at the ready. cmon guys pitch in Quote
Happy Hobbit Posted April 30, 2016 Author Posted April 30, 2016 Lee Mac, TharWat, David Bethnal, where art thou when I needeth you? Quote
Tharwat Posted April 30, 2016 Posted April 30, 2016 Hi guys. My method: (setq lst '(("1" . 1) ("A" . 1) ("C" . 2) ("3" . 1) ("B" . 5) ("D" . 2) ("2" . 3) ("E" . 5))) (setq z (vl-sort lst '(lambda (j k) (< (car j) (car k))))) (while z (if (numberp (read (caar z))) (setq b (append b (list (car z)))) (setq a (append a (list (car z)))) ) (setq z (cdr z)) ) (if (and a b) (append a b)) Quote
pBe Posted April 30, 2016 Posted April 30, 2016 Lee Mac, TharWat, David Bethnal, where art thou when I needeth you? its the weekend after all. if i were to guess, i may use numberp and ascii for this, that is if we're to continue using vl-sort. Quote
Tharwat Posted April 30, 2016 Posted April 30, 2016 Another with mapcar & lambda functions and it is not that different than the one posted earlier by me with while function: (setq lst '(("1" . 1) ("A" . 1) ("C" . 2) ("3" . 1) ("B" . 5) ("D" . 2) ("2" . 3) ("E" . 5))) (setq z (vl-sort lst '(lambda (j k) (< (car j) (car k))))) (mapcar '(lambda (x) (if (numberp (read (car x))) (setq b (append b (list x))) (setq a (append a (list x))) ) ) z ) (if (and a b) (append a b)) Quote
pBe Posted April 30, 2016 Posted April 30, 2016 (edited) @tharwat Can it be done inside vl-sort? i think its doable Edited April 30, 2016 by pBe Quote
David Bethel Posted April 30, 2016 Posted April 30, 2016 I do not remember who wrote this but it is VERY old ;;****************************************************** ;; ********************* SORTDPLST ********************* ;;****************************************************** ; (SORTDPLST <List_of_lists>) ; Sorts a list of lists (or dotted pairs) by the first element ; in ascending order. The first elements may be either all numeric or ; all strings. (defun SortDpLst (dpl / len ctr start mcg rlen minimum) (defun minimum (lst) (if (= (type (car lst)) 'STR) (car (acad_strlsort lst)) (apply 'min lst) ) ) (setq len (length dpl) ctr 0 start nil) (cond ((> len 2) (setq mcg (minimum (mapcar 'car dpl))) ; get smallest value (setq mcg (assoc mcg dpl)) (setq rlen (- len (length (member mcg dpl)))) ; get position in list (while (< ctr rlen) ; remove minimum from list (setq start (cons (nth ctr dpl) start)) (setq ctr (1+ ctr)) ) (setq dpl (cons mcg (sortdplst (append (reverse start) ; reconstruct list (cdr (member mcg dpl)))))) ) ((= len 2) (if (/= (minimum (mapcar 'car dpl)) (caar dpl)) (setq dpl (reverse dpl)) ) )) dpl ) https://www.theswamp.org/index.php?topic=29333.0 Quote
Tharwat Posted April 30, 2016 Posted April 30, 2016 I think it would be nice to write my name correctly, right? Quote
pBe Posted April 30, 2016 Posted April 30, 2016 I think it would be nice to write my name correctly, right? My mistake my friend [ fixed name at post 13 ] As for Happy Hobbit's lesson for the day (without stepping out of vl-sort) (vl-sort lst '(lambda (a b) (setq c (mapcar '(lambda (d) (if (> (Setq e (Ascii d)) 57) (- e 50) e ) ) (mapcar 'car (list a b)) ) ) (< (Car c) (cadr c)) ) ) NOTE TO SELF: (NTS) Needs to out put more thought on the code if the conditions are different than the one posted by the OP Quote
Tharwat Posted April 30, 2016 Posted April 30, 2016 Here is another method (mapcar '(lambda (x) (setq order (append order (list (assoc (chr (if (< x 48) (+ x 33) x)) lst))) ) ) (vl-sort (mapcar '(lambda (x) (if (<= 48 (setq v (ascii (car x))) 57) v (- v 33))) lst) '<) ) The output would be in variable 'order' Quote
Lee Mac Posted April 30, 2016 Posted April 30, 2016 (setq lst '(("1" . 1) ("A" . 1) ("C" . 2) ("3" . 1) ("B" . 5) ("D" . 2) ("2" . 3) ("E" . 5))) (setq z (vl-sort lst '(lambda (j k) (< (car j) (car k))))) (while z (if (numberp (read (caar z))) (setq b (append b (list (car z)))) (setq a (append a (list (car z)))) ) (setq z (cdr z)) ) (if (and a b) (append a b)) (setq lst '(("1" . 1) ("A" . 1) ("C" . 2) ("3" . 1) ("B" . 5) ("D" . 2) ("2" . 3) ("E" . 5))) (setq z (vl-sort lst '(lambda (j k) (< (car j) (car k))))) (mapcar '(lambda (x) (if (numberp (read (car x))) (setq b (append b (list x))) (setq a (append a (list x))) ) ) z ) (if (and a b) (append a b)) (vl-sort lst '(lambda (a b) (setq c (mapcar '(lambda (d) (if (> (Setq e (Ascii d)) 57) (- e 50) e ) ) (mapcar 'car (list a b)) ) ) (< (Car c) (cadr c)) ) ) (mapcar '(lambda (x) (setq order (append order (list (assoc (chr (if (< x 48) (+ x 33) x)) lst))) ) ) (vl-sort (mapcar '(lambda (x) (if (<= 48 (setq v (ascii (car x))) 57) v (- v 33))) lst) '<) ) Try these lists: (setq lst '(("10" . 3) ("A" . 1) ("3" . 1) ("1" . 3) ("2" . 3))) (setq lst '(("10" . 3) ("A" . 1) ("3" . 1) ("1" . 3) ("1" . 4) ("1" . 5) ("2" . 3))) (setq lst '(("10" . 3) ("3" . 1) ("1" . 3) ("2" . 3))) Here is another: (defun foo ( l ) (vl-sort l '(lambda ( a b / x y ) (setq x (read (car a)) y (read (car b))) (cond ( (and (numberp x) (numberp y)) (< x y)) ( (numberp y)) ( (numberp x) nil) ( (< (car a) (car b))) ) ) ) ) Quote
Lee Mac Posted April 30, 2016 Posted April 30, 2016 Our limits were up to 9 With no duplicate keys and always a mix of letters & numbers. Quote
