BWW Posted May 1, 2016 Share Posted May 1, 2016 (edited) Hope this is the right spot for this. When I use the CUI to customize a ribbon, in what I thought was a specific work space, the customization appears in the ribbon in all work spaces. If I set the ribbon I want to customize as current and make changes, those changes appear in the current ribbon and the ribbons in all other work spaces too. That wasn't exactly accurate. If I add a tab to a ribbon in a specific work space with the "customize work space" clicked (all turns blue under chosen work space) then that tab only appears in that work space ribbon. However, if I add a panel to an existing tab, which I can't seem to do in customize work space mode, then that change happens in all work space ribbons. just feel like I'm missing something. I'll add that if I add a panel onto a tab the panel appears in the tab but does not appear anywhere in the customize work space window. I thought I might hide the panel in the work spaces I didn't want to see the panel but the new panel simply isn't there to hide. Edited May 1, 2016 by BWW Quote Link to comment Share on other sites More sharing options...
