hi
using acad 2010,
is there a way to make a viewport a new named view in model space?
Pretty sure this has been asked before, you can get properties of a named view so should be able to make a viewport version.
(setq  doc (vla-get-activedocument (vlax-get-acad-object))) ; open database
(setq allviews (vla-get-views doc))
(vlax-for each allviews (vla-get-name each))
;(vlax-for each allviews (vlax-Dump-Object each))
If you are working through a maximized viewport you can create a new saved view, either with, or without a saved layer snapshot, and you can either save the whole view, or define it with a crossing window.
Not sure if that helps you or not, but sounds pretty close to what you are asking about. :|
