Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Forum Newbie
    AutoCAD 2014
    May 2016
    3
    Default Penn Foster Basketball autocad project
    I am working on the basketball project now. I can't seem to figure out the distance from the rim to the shot arm mounting block on the top view. Help??? There doesn't show this distance anywhere in the provided info...
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,954
    No need to double post.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I may be able to assist you but my documentation is at work and I'm at home now. Perhaps tomorrow? I'll check this thread in the morning when I get into my office. That's the best I can offer at the moment.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Good Morning.
    As promised I am checking in. For a moment I thought I had lost the set of instructions for this project but a post in a previous thread about it finally led me to the source. You asked about the distance from the rim to the shot arm mounting block in the top view. You correctly state it is not specifically called out in the project instructions for the top view nor is it referenced in the side view. I also checked the written description for the mounting block and the court/base but they too fail to provide a dimension. Therefore you have two choices available to you. 1) Guesstimate. 2) Email or call your instructor and ask if he/she can provide you with some clarity (i.e. - an actual dimension). Note: The two provided sketches do not provide the student with enough dimensions to calculate the distance and I notice that the centerlines of the two pan head screws used to secure the mounting block to the court/base are not dimensioned either (nor are those dimensions provided in the text). Classic Penn-Foster screw up.
    Caveat: My copy of the PDF which contains the instructions for this project dates from 2013 so it may not be entirely up-to-date. If you feel comfortable sharing a copy of the instructions you have I would be willing to look into this further. Of course that means I am assuming P-F corrected any errors and omissions which normally doesn't happen at all or takes a very long time. I've gone through this with a couple of the other projects (ex. - Oleson Village) so I know what is involved.
    I never did this project but looking at the instructions I notice a couple of other instances where P-F fails to provide the student with the required information. Ex. - size of socket head cap screws and distance from centerline of backboard to centerline of cap screws. In my opinion the version I have is poorly written.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    shamm: Where did you go? Did you give up already?
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    An interesting little project that once again Penn-Foster manages to provide inaccurate information for or information is missing. None-the-less here is my take on it based upon the project instructions from three years ago. First up is the top, front and side views with projection lines added of my own accord.
    Yes, the hidden lines are dashed but to see them I'd have to provide individual images for each view like this.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Next up is a 3D model. Not required by P-F but I thought I would use it to generate 2D views created using the Flatshot command.
    Can't really see the cap screws that attach the rim to the backboard or those that attach the shot arm mounting block (pinkish color) to the court/base (yellow color) nor is the countersunk screw all that easy to see (connects shot arm, in red, to mounting block). These will require slightly different, close up, views.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Here is a closeup of the back of the backboard, in X-Ray visual style, showing the socket head cap screws that hold the rim on and how the top of the post is fitted to the backboard.
    Closeup of shot arm showing countersunk (phillips head)screw. I substituted this screw for the pan head machine screw called for in the instructions.
    And a closeup of the bottom of the court/base showing the socket head cap screws used to attach the shot arm mounting base.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Next up are the three standard views derived from the 3D model using the Flatshot command. Hidden lines are dashed and in blue.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    OK...last two. The first one is a basic exploded view. The second is a section cut through the backboard and rim shown in a X-Ray visual style.
    In the course of doing this project I found the images to be somewhat misleading so I would recommend the student treat them as a general guide. It would have been helpful to have the size of the socket head cap screws and the dimensions relating to the centerlines called out. I substituted a countersunk screw for the pan head machine screw called for in the instructions because I felt it made more sense (a pan head machine screw would not have been flush with the end of the shot arm). The size and dimensions for this screw should have been called out as well. The location of the first hole for the scoring pins should have been better defined. And there is no clear indication as to the location of the shot arm mounting block. Why wasn't a dimension from the edge of the court/base provided? Students doing this project would be wise to contact their instructor for clarification on these and other matters affecting this project. Good luck.
  1. looking for feedback on my structural project for penn foster
    By justrideemall in forum Student Project Questions
    Last Post: 25th Oct 2015, 11:45 pm
  2. Penn Foster Basketball court project
    By cosme017 in forum Student Project Questions
    Last Post: 30th Jan 2015, 01:21 pm
  3. Penn Foster Civil Drafting With Autocad Project 6
    By taylorklepal in forum Student Project Questions
    Last Post: 21st Aug 2013, 11:25 am
  4. penn foster oleson project
    By jimbobjewel in forum Student Project Questions
    Last Post: 29th Aug 2012, 10:47 am
  5. Penn and Foster Structural Project Help
    By robxfinch in forum Student Project Questions
    Last Post: 20th Nov 2011, 03:31 am
