lisp needed : extract poly line vertex X,Y into txt file
hi everybody i will be thank's if someone help me:-
i have poly line with 50 vertex i need lisp to extract this vertex coordinates X,Y into text file
Hi,
Is it LWpolyline or 3Dpolyline?
2D polyline
With comma or space separated?
with comma please
Last question: what about the precision number of coordinates ?
3 number and i will be thank's for help
Try it and let me know:
(defun c:Test (/ ss fl op)
 ;; Tharwat. 11.May.16	;;
 (princ "\nSelect LWpolylines:")
 (and (setq ss (ssget '((0 . "LWPOLYLINE"))))
      (setq fl (getfiled "Specify txt file name:" (getvar 'DWGPREFIX) "txt" 1))
      (setq op (open fl "w"))
        ((lambda (i / sn p)
           (while (setq sn (ssname ss (setq i (1+ i))))
             (mapcar '(lambda (x) (and (= (car x) 10)
                                       (setq p (cdr x))
                                       (write-line (strcat (rtos (car p) 2 3) "," (rtos (cadr p) 2 3)) op ) )
                     (entget sn)
          -1
        (close op)
        ((lambda (i / sn p)
                                       (setq p (cdr x))
                     (entget sn)
          -1
        (close op)
perfect work man thank's very much
جزاك الله خيرا
Tharwat being awesome as always. :D
That's too kind of you to say. :thumbsup:
  • 1 year later...
