Deby Ferdian Posted May 19, 2016 Share Posted May 19, 2016 Because I intend to create a sectionplane to the object what I will wish to give the material property to it and then so I can look in a technically by definitely completely clearly and because till the day I only can give it material into only a face of an object.. #sorry for my bad english,, Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 19, 2016 Share Posted May 19, 2016 Can't you just apply the material to the exposed face to simulate that affect? Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted May 19, 2016 Author Share Posted May 19, 2016 (edited) You mean give the material with face by face ??? But it's looks like it must be exploded away first before I give it a material and otherwise when I exploded it's crack and seperate by face and the resort be empty it don't have a solid profile anymore. It doesn't good! #sorry about my poor english,, Edited May 19, 2016 by Deby Ferdian Correction! Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted May 19, 2016 Author Share Posted May 19, 2016 (edited) I was did by configure the livesection settings with the right-click shell menu pop-up of the section was created an earlier and don't apply or don't show about intersection fill maybe this might you mean to be. right ??? The only one of my problem now after the result appears good but seems look there is a line have chain along the edge of my seperate by livesection it was gray color of the line,, How to hide or remove it ? Edited May 20, 2016 by Deby Ferdian Uploaded more pictures! Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted May 20, 2016 Author Share Posted May 20, 2016 maybe it's call with intersection boundary. But I don't know how to remove it ? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 20, 2016 Share Posted May 20, 2016 Maybe it has something to do with the way you created the 3D model in the first place. Can't say for sure. Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted May 20, 2016 Author Share Posted May 20, 2016 Could you tell me @ReMark how to fix that ? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 20, 2016 Share Posted May 20, 2016 I've never had such a problem and even with a copy of the drawing to analyze I'm not sure I could tell you how to fix it. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 20, 2016 Share Posted May 20, 2016 Does the line still appear when you render? Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted May 20, 2016 Author Share Posted May 20, 2016 (edited) The rendering operation has done with completely remove all of the line. thank you @Cad64 you have helped me but in necessary question How do we did this without rendering methode ? Because it's very very interrupting my adjustment on process of drawing.. Edited May 20, 2016 by Deby Ferdian Corrections! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 20, 2016 Share Posted May 20, 2016 Check the edge settings in your Visual style. Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted May 20, 2016 Author Share Posted May 20, 2016 (edited) Yes I have,, I was go with and check them one by one such as; realistic, conceptual, shaded, shaded with edges, shaded of gray, x-ray and sketchy,, But the resort still be there is no progress at all.. or could be you mean there is spesific confirgure to re-setting up this all. Edited May 20, 2016 by Deby Ferdian Correction! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 20, 2016 Share Posted May 20, 2016 Type VISUALSTYLES at the command line. This will open the Visual Styles palette where you can adjust settings. Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted May 20, 2016 Author Share Posted May 20, 2016 seems like there is no kind of an option like that or something could be fix it. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 21, 2016 Share Posted May 21, 2016 I don't know. I'm out of ideas. Why is this a problem though? The lines don't show up when you render, so why does it matter if you see them while you're working? Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted May 21, 2016 Author Share Posted May 21, 2016 (edited) Yeah.. Indeed, you well right absolutely correct @Cad64,, I just thought. Is it possible to hide them ??? Edited May 21, 2016 by Deby Ferdian Create Expression! Quote Link to comment Share on other sites More sharing options...
