attribute with a field
samifox
using acad 2010,
im creating an attribute with a field that show the length of a polyline,
the problem is that the field is not regenerated after stretching.
i've attached the block,
TX
DBLKdwg.dwg
Fields and attributes in dynamic blocks are tricky, it would appear that though a field on its own will update, a field inside an attribute remains linked to the value contained in the block description unless it refers to a dynamic parameter, (and that has it's own set of rules). I added another dynamic parameter and used a formula with fields that reads those values, does this approach what you are trying to do.
DBLKdwg.dwg
