"Select all that crosses in multiple boxes But omit the box in the selection" lisp
Been using this "select in cross box" lisp by Tharwat & is good.
But I have 2 request.
1. Please allow to able to select multiple box
2. After selecting everything in the multiple cross box, exclude the box from the selection
(defun c:SIB (/ s ss sel)
 ;;    Tharwat 30. May. 2014        ;;
 (if (setq s  (ssadd)
           ss (ssget (list '(0 . "LWPOLYLINE")
                           '(-4 . "&=")
                           '(70 . 1)
                           (cons 410 (getvar 'CTAB))
   ((lambda (j / sn n d l pts)
      (while (setq sn (ssname ss (setq j (1+ j))))
        (setq l   (vlax-curve-getdistatparam sn (vlax-curve-getendparam sn))
              d   (/ l 250.)
              n   d
              pts nil
        (repeat 250
          (setq pts (cons (vlax-curve-getpointatdist sn n) pts)
                n   (+ n d)
        (if (setq sel (ssget "_CP" pts))
          ((lambda (i / en)
             (while (setq en (ssname sel (setq i (1+ i))))
               (ssadd en s)
            -1
     -1
 (sssetfirst nil s)
Edited by Tripledot
You need to use Code Tags instead of Quote Tags for your Code. [NOPARSE]
Your Code Here
[/NOPARSE]=
Your Code Here
Your Code Here
[/NOPARSE]=
Your Code Here
My mistake. Updated.
Edited by Tripledot
Hi,
The program asks you to select closed lwpolylines so what do you mean by the following question?
For the second question just replace this line (ssadd en s) with the following :
(if (not (eq sn en))
      (ssadd en s)
Hi,
      (ssadd en s)
Thanks Tharwat. That change worked. Also i forgotten that it can select multiple boxes so can ignore the 1st question.
Thanks
Tharwat. I encounter an issue. It can only select with I am in WORLD UCS. Can make it possible to select in other UCS?
Replace the following:
(setq pts (cons (trans (vlax-curve-getpointatdist sn n) 1 0) pts)
I think it would need to be:
(trans < ... > 0 1)
Opps. I should not have replied that fast which cause that big mistake to occur. :(
no issue Tharwat. Only got the chance to test it just.
Too be sure, this would be the code?
(setq pts (cons (trans (vlax-curve-getpointatdist sn n) 0 1) pts)
Edited by Tripledot
Edit
I just realise that Lee posted the correction. Though both post were by Tharwat. Hence I got confused.
Thanks Lee & Tharwat for the help. Working now.
  • 1 month later...
Hi Tharwat.
I now face an issue. I need to select those items not crossing or touching the selected polyline but only those that are completely inside.
Can you advise on the code to only select entities completely inside the selected closed polyline?
Thanks
Hi,
Just replace "_CP" with "_WP" in the following codes;
(ssget "_CP" pts)
There is lots of ssget options a couple
CP crossing polygon
WP within polygon
W a window of two points
F a fence or like a pline crossing objects
