zwonko Posted June 18, 2016 Share Posted June 18, 2016 Hello, could You help me with LISP that will do stuff like this: 1) I have a some polylines on drawing. All are closed. I start the lisp and could select one. 2) Selected (1st) polyline should be _extrude 12 units to create 1st 3DSolid 3) then this selected 1st polyline should be _offset 0.8 units to create 2nd poly 4) 2nd poly should be extruded 12 units to create 2nd 3DSolid 5) 2nd poly should be offset 0.4 units to create 3rd poly. (or alternatively it could be that 1st should be offset 1.2 units) 6) 3rd poly should be extrude 5 units to create 3rd 3DSolid 7) 3rd poly should be offset 4.8 units (or arternatively 1st should be offset 6 units) to create 4th poly 8 ) 4th poly should be extrude 2 units. 9) last thing substract selects 2nd 3rd and 4rd 3Dsolids, and cut off 1st 3DSolid All offset must be outside. All extrude should be up (Z axis possitive) I will be gratefull if the lisp run command with "_" (_extrude, _offset, _substract) becouse I use not english version of autocad. But i could change it myself. Cool thing will be if I can select not only one poly but few polylines and they all do as i written above. But it could be hard. I think that the worst thing in this is to automaticaly select created 3DSolids so I think that LISP may only start substract command and I will select 3Dsolids manually. If it is possible to select few polylines and do Offset&Extrude, and after that substract must be done manually it will be awesome if substract command is started few times (for example 3 polylines select and the lisp starts substract three times) I've attached the file that shows the start&result of my work. I have to do all alphabet letters like this "&" Now I' doing it with two lisp (which I moddified from lisps founded in the internet) (defun c:pof1 (/ plines ; selection set of polylines ext ; extrnal point poly ; a polyline from plines plist ; the list of poly del ; polyline to delete int ; internal point i) (command "undo" "begin") (princ "select polylines") (setq plines (ssget) i 0 ext (getvar "limmax") ) (repeat (sslength plines) (setq poly (ssname plines i)) (setq plist (entget poly)) (command "_offset" 0.8 poly ext "") (command "_offset" 1.2 poly ext "") (command "_offset" 6 poly ext "") ) ) (defun c:pof2 (/ plines ; selection set of polylines ext ; extrnal point poly ; a polyline from plines plist ; the list of poly del ; polyline to delete int ; internal point i) (command "undo" "begin") (princ "select polylines") (setq plines (ssget) i 0 ext (getvar "limmax") ) (repeat (sslength plines) (setq poly (ssname plines i)) (setq plist (entget poly)) (command "_extrude" poly "" 12 "") / plines ; selection set of polylines ext ; extrnal point poly ; a polyline from plines plist ; the list of poly del ; polyline to delete int ; internal point i) (command "undo" "begin") (princ "select polylines") (setq plines (ssget) i 0 ext (getvar "limmax") ) (repeat (sslength plines) (setq poly (ssname plines i)) (setq plist (entget poly)) (command "_extrude" poly "" 12 "") / plines ; selection set of polylines ext ; extrnal point poly ; a polyline from plines plist ; the list of poly del ; polyline to delete int ; internal point i) (command "undo" "begin") (princ "select polylines") (setq plines (ssget) i 0 ext (getvar "limmax") ) (repeat (sslength plines) (setq poly (ssname plines i)) (setq plist (entget poly)) (command "_extrude" poly "" 5 "") / plines ; selection set of polylines ext ; extrnal point poly ; a polyline from plines plist ; the list of poly del ; polyline to delete int ; internal point i) (command "undo" "begin") (princ "select polylines") (setq plines (ssget) i 0 ext (getvar "limmax") ) (repeat (sslength plines) (setq poly (ssname plines i)) (setq plist (entget poly)) (command "_extrude" poly "" 2 "") (command "_subtract" ) ) ) lisp.dwg Quote Link to comment Share on other sites More sharing options...
lamensterms Posted June 26, 2016 Share Posted June 26, 2016 Without looking too deeply into the code you already have, I would recommend you explore SSGET "L" (last) to store each element (polyline & 3D solid) in a selection set, so you can recall them when coming to subtract from each other. I'd be happy to take another look when I get to a computer, but chances are you'll be able to get some even better help from someone else on the forum before I can get back to it. Quote Link to comment Share on other sites More sharing options...
zwonko Posted June 26, 2016 Author Share Posted June 26, 2016 @lamensterms that was everything that I need I've modyfied code form lisp1 (pof1) to: (defun c:pof3 (/ plines ; selection set of polylines ext ; extrnal point poly1 ; a polyline from plines poly2 ; a polyline from plines poly3 ; a polyline from plines poly4 ; a polyline from plines extr1 ; a extrude from plines extr2 ; a extrude from plines extr3 ; a extrude from plines extr4 ; a extrude from plines plist ; the list of poly del ; polyline to delete int ; internal point i) (command "undo" "begin") (princ "select polylines") (setq plines (ssget) i 0 ext (getvar "limmax") ) (repeat (sslength plines) (setq poly1 (ssname plines i)) (setq plist (entget poly1)) (command "_offset" 0.8 poly1 ext "") (setq poly2 (ssget "_L")) (command "_extrude" poly1 "" 12 "") (setq extr1 (ssget "_L")) (command "_offset" 0.4 poly2 ext "") (setq poly3 (ssget "_L")) (command "_extrude" poly2 "" 12 "") (setq extr2 (ssget "_L")) (command "_offset" 4.8 poly3 ext "") (setq poly4 (ssget "_L")) (command "_extrude" poly3 "" 5 "") (setq extr3 (ssget "_L")) (command "_extrude" poly4 "" 2 "") (setq extr4 (ssget "_L")) (command "_subtract" extr2 extr3 extr4 "" extr1 "") ) ) everything works great Maybe code is not the simplest but its works Quote Link to comment Share on other sites More sharing options...
lamensterms Posted June 27, 2016 Share Posted June 27, 2016 Well done, glad you got it going. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 1, 2016 Share Posted July 1, 2016 Just a suggestion (Setq ent1 (entlast)) no need for ssget You are setting a variable to a entity so no need to use a selection set Quote Link to comment Share on other sites More sharing options...
