samifox Posted June 21, 2016 Share Posted June 21, 2016 hi, i dont understand what ACAD operating system environmental variable means? it is windows related variable? if you read the documantation , notice that the variable is not saved which means is a windows variable? and what is the different between (getvar "acadprefix") to (getenv "acad")? TX Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 21, 2016 Share Posted June 21, 2016 (getenv "acad")? I agree ???? is this what your after (vlax-product-key) Quote Link to comment Share on other sites More sharing options...
samifox Posted June 21, 2016 Author Share Posted June 21, 2016 (getenv "acad")? I agree ???? is this what your after (vlax-product-key) IM LOST! whay product key has to do with this veriable? Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 21, 2016 Share Posted June 21, 2016 and what is the different between (getvar "acadprefix") to (getenv "acad")? ACADPREFIX is read-only. It only reports the support file search path. You can't do a (setvar "ACADPREFIX" "......") (getenv "ACAD") also reports the same info, but you can also use (setenv "ACAD" ".....") to change it. Quote Link to comment Share on other sites More sharing options...
samifox Posted June 21, 2016 Author Share Posted June 21, 2016 ACADPREFIX is read-only. It only reports the support file search path. You can't do a (setvar "ACADPREFIX" "......")(getenv "ACAD") also reports the same info, but you can also use (setenv "ACAD" ".....") to change it. what is the concept of environment variable? Quote Link to comment Share on other sites More sharing options...
tombu Posted June 21, 2016 Share Posted June 21, 2016 AUTODESK KNOWLEDGE NETWORK About System and Environment Variables (AutoLISP) https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-AutoLISP/files/GUID-529819FD-9E9C-4789-BA18-B981BA32DD23-htm.html Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 21, 2016 Share Posted June 21, 2016 what is the concept of environment variable? See also: AutoCAD Environment Variables Quick Guide, specifically the header paragraph. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 22, 2016 Share Posted June 22, 2016 My (getenv "acad") gave me nil maybe its another Windows 10 bug, or it was my typing and drinking scotch at the same time. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 22, 2016 Share Posted June 22, 2016 Environment variables are case sensitive. Try (getenv "ACAD") Quote Link to comment Share on other sites More sharing options...
tombu Posted June 22, 2016 Share Posted June 22, 2016 My (getenv "acad") gave me nil maybe its another Windows 10 bug, or it was my typing and drinking scotch at the same time. Text case is important with environmental variables. Try it again with (getenv "ACAD") samifox had it wrong in his first post as well. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 23, 2016 Share Posted June 23, 2016 See it was not the scotch ! Quote Link to comment Share on other sites More sharing options...
