I am using attributed text wire tags. I was wondering if there is a quick way to add a D to the front of my wire tag? The fastest way I have found so far is using the properties box EX. tag S,V. When I select multiple wire tags S,V on my wire run and the S,V shows up in the properties box then I can add my D. If I have a SV 2S,V 2S,2V selected then the properties box says varies. Is there a lisp or a solution to this problem?
Try the following:
(defun c:attps ( / a b c e i s x )
   (setq a (getstring t "\nSpecify prefix <none>: ")
         b (getstring t "\nSpecify suffix <none>: ")
         c [highlight]"S,V" ;; Attribute Tag - change to suit[/highlight]
   (if (setq s (ssget "_:L" '((0 . "INSERT") (66 . 1))))
       (repeat (setq i (sslength s))
           (setq e (entnext (ssname s (setq i (1- i))))
                 x (entget e)
           (while (= "ATTRIB" (cdr (assoc 0 x)))
               (if (= (cdr (assoc 2 x)) c)
                   (entmod (subst (cons 1 (strcat a (cdr (assoc 1 x)) b)) (assoc 1 x) x))
               (setq e (entnext e)
                     x (entget  e)
