Hi,
I not regularly use trans function in my routine, so quite new to understand this functions behavior.
I have attached drawing contains two rectangles with at different planes or you can say UCS. I want to draw circle at the centroid of that rectangle, I have already mark centroid of that rectangles.
Can anyone provide help with sample code?
Test for Trans.dwg
Do you want to draw circles or (entmake/entmakex) them?
I want to draw circles in that rectangle using entmake function
Not tested :
(defun c:cirec ( / s rec cen )
 (prompt "\nPick rectangle...")
 (setq s (ssget "_+.:E:S" (list '(0 . "LWPOLYLINE") '(90 . 4) '(-4 . "<or") '(70 . 1) '(70 . 129) '(-4 . "or>"))))
 (while (or (not s) (not (vl-every '(lambda ( x ) (= (cdr x) 0.0)) (vl-remove-if-not '(lambda ( x ) (= (car x) 42)) (entget (ssname s 0))))))
   (prompt "\nEmpty sel.set or picked LWPOLYLINE not polygonal - has arced segments... Retry selection pick again...")
 (setq rec (ssname s 0))
 (setq cen (trans (list (/ (+ (car (cdr (assoc 10 (entget rec)))) (car (cdr (assoc 10 (cdr (member (assoc 10 (cdr (member (assoc 10 (entget rec)) (entget rec)))) (entget rec))))))) 2.0) (/ (+ (cadr (cdr (assoc 10 (entget rec)))) (cadr (cdr (assoc 10 (cdr (member (assoc 10 (cdr (member (assoc 10 (entget rec)) (entget rec)))) (entget rec))))))) 2.0) (cdr (assoc 38 (entget rec)))) rec 0))
 (entmake
   (list
     '(0 . "CIRCLE")
     '(100 . "AcDbEntity")
     '(100 . "AcDbCircle")
     (cons 8 "YourLayer") ;; <- change
     (cons 10 (trans cen 0 rec))
     (cons 40 10.0) ;; <- change radius you want
     '(62 . 1) ;; <- change color from red to what you want or remove this line
     (assoc 210 (entget rec))
[EDIT : The code was tested and modified...]
Edited by marko_ribar
missed to input (cdr (assoc 38 (entget rec))) as Z coordinate of cen variable
It is giving weird result, Circles are getting drawn at wrong place... Can you please test it with my drawing
I see it... It's now fine...
HTH, M.R.
Wow....thanks a lot... really appreciated your effort :notworthy:
(defun c:ccen ( / e i l s )
   (if (setq s (ssget '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&=") (70 . 1) (-4 . "<NOT") (-4 . "<>") (42 . 0.0) (-4 . "NOT>"))))
       (repeat (setq i (sslength s))
           (setq e (entget (ssname s (setq i (1- i))))
                 l (apply 'mapcar (cons '+ (vl-remove-if-not '(lambda ( x ) (= 10 (car x))) e)))
           (entmake
               (list
                  '(000 . "CIRCLE")
                  '(040 . 100.0)
                   (append (mapcar '/ l '(4 4.0 4.0)) (list (cdr (assoc 38 e))))
                   (assoc 210 e)
@ marko_ribar:
The use of the trans function is superfluous here:
(setq cen (trans ... rec 0))
           (entmake
               (list
                  '(000 . "CIRCLE")
                  '(040 . 100.0)
                   (assoc 210 e)
Lee Sir, That was brilliant :shock:
@ marko_ribar:
Roy I know that, I only wanted to show to OP how (trans) can be used... I tend to convert points from OCS to WCS, then perform desired calculations with them and if its necessary (trans)late them back to OCS... Beside that using (vlax-curve-*) functions always return WCS coordinates, so better use to manipulate with WCS points and terms and code for such situations where you can't for sure rely on OCSs before you make desired (trans)lations...
