pmxcad Posted June 29, 2016 Posted June 29, 2016 Hello, i found a lisp on the web and like this lisp but could it be made that i have a third option "both" , inside and crossing. (defun c:SWCC (/ _pac add ss i e temp it o a b pts tempC i3 ec) ;; Select Within/Crossing Curve ;; Alan J. Thompson, 03.31.11 / 05.11.11 (vl-load-com) (defun _pac (e / l v d lst) (setq d (- (setq v (/ (setq l (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e))) 100.)))) (while (< (setq d (+ d v)) l) (setq lst (cons (trans (vlax-curve-getPointAtDist e d) 0 1) lst)) ) ) (initget 0 "Crossing Within") (setq *SWCC:Opt* (cond ((getkword (strcat "\nSpecify selection method witin curve [Crossing/Within] <" (cond (*SWCC:Opt*) ((setq *SWCC:Opt* "Crossing")) ) ">: " ) ) ) (*SWCC:Opt*) ) ) (princ "\nSelect closed curves to select object(s) within: ") (if (setq add (ssadd) ss (ssget '((-4 . "<OR") (0 . "CIRCLE,ELLIPSE") (-4 . "<AND") (0 . "*POLYLINE") (-4 . "&=") (70 . 1) (-4 . "AND>") (-4 . "OR>") ) ) ) (progn (repeat (setq i (sslength ss)) (if (setq temp (ssget "_WP" (_pac (setq e (ssname ss (setq i (1- i))))))) (repeat (setq i2 (sslength temp)) (ssadd (ssname temp (setq i2 (1- i2))) add)) ) (if (eq *SWCC:Opt* "Crossing") (progn (vla-getboundingbox (setq o (vlax-ename->vla-object e)) 'a 'b) (setq pts (mapcar 'vlax-safearray->list (list a b))) (if (setq tempC (ssget "_C" (list (caar pts) (cadar pts) 0.) (list (caadr pts) (cadadr pts) 0.) ) ) (repeat (setq i3 (sslength tempC)) (if (vlax-invoke o 'Intersectwith (vlax-ename->vla-object (setq ec (ssname tempC (setq i3 (1- i3))))) acExtendNone ) (ssadd ec add) ) ) ) ) ) ) (sssetfirst nil add) (ssget "_I") ) ) (princ) ) thanks PmxCAD Quote
pkenewell Posted June 29, 2016 Posted June 29, 2016 Hello,i found a lisp on the web and like this lisp but could it be made that i have a third option "both" , inside and crossing. thanks PmxCAD I'm not really sure what your asking? When you say "Both" - that's exactly what the "Crossing Selection" should include - both the objects inside and the objects crossing the boundary. Quote
