SSGET Filter Failing for Particular Object Type
lamensterms
Hi,
I've been having some trouble getting SSGET filters to recognise a particular ProSteel element type (called "Ks_VolBody"). In my experience SSGET filters work fine with all other ProSteel element types, just not "Ks_VolBody".
The problem is that (SSGET "X" '((0 . "Ks_VolBody"))) will not detect/select this element type.
According to these following commands, this 'entity type' is as follows:
LIST = Ks_VolBody
Properties Palette = Ks_VolBody
DUMPIT = ObjectName (RO) = "Ks_VolBody"
ENTGET>ENTLAST = (0 . "Ks_VolBody")
All other data returned by ENTGET>ENTLAST = ((-1 . ) (0 . "Ks_VolBody") (330 . ) (5 . "20621") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "PS_BOLT"))
(SSGET "X" '((0 . "K*"))) will detect these elements, but also selects all other ProSteel elements.
(SSGET "X" '((0 . "Ks*"))) will not detect these elements, but selects all other ProSteel elements.
(SSGET "X" '((0 . "K"))) returns nil.
I realise this will be hard or impossible for a lot of you to test, but I'm wondering if perhaps there could be another way for SSGET to filter these elements, or if there is another way to learn the true 'entity type' for these elements.
DWG attached.
Thanks a lot for any help.
Ks_VolBody Test.dwg
Hey Roy-043,
Thanks a lot for the reply.
Unfortunately (ssget "_X" '((0 . "ACAD_PROXY_ENTITY") (1 . "Ks_VolBody"))) returns 'nil'.
Maybe it has changed, but group 0 has historically been UPPERCASE . Did you try that ?
-David
Thanks for the reply David.
I've just tried UPPERCASE versions and they still return nil.
Does the following return a valid selset?
(ssget "_X" '((0 . "ACAD_PROXY_ENTITY")))
If so, you may need to obtain the initial selection set using this, and then filter further within the processing loop.
Actually I did some testing and I don't think my last guess will work. But this one might:
(ssget "_X" '((-4 . "<AND") (0 . "K*") (0 . "~Ks*") (-4 . "AND>")))
Thanks a lot for the replies everyone.
@Lee
unfortunately returns 'nil'.
@a_67vdub
seems to work well so far, thanks for suggesting that.
I was hoping for a more specific solution (if one exists). But the above code does work.
Thanks for the help everyone.
