cat3appr Posted July 4, 2016 Share Posted July 4, 2016 hello all of a sudden my DWG got the same dwg xreffed to itself and i cannot detouch it.... i'm getting the error as in the screenshot. anyone has an idea on how to get rid of this extra twin xref? the bizarre thing is that the DWG opens normally in other machines... many thanks! Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 4, 2016 Share Posted July 4, 2016 Have you tried using the ERASE command?. Quote Link to comment Share on other sites More sharing options...
cat3appr Posted July 4, 2016 Author Share Posted July 4, 2016 please explain the procedure, do I have to right click on the xref and find an "erase" ? now the double xref is not even right clickable.... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 4, 2016 Share Posted July 4, 2016 ERASE like you would any other object. There are a number of ways to execute this command. Quote Link to comment Share on other sites More sharing options...
cat3appr Posted July 4, 2016 Author Share Posted July 4, 2016 ERASE like you would any other object. There are a number of ways to execute this command. no, it doesn't work like that. please if you know this procedure, can you write it step by step, cheers Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 4, 2016 Share Posted July 4, 2016 There is an error message in your command line leading me to believe that there is some sort of LISP or other code running. It is too blurry for me to read clearly. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 4, 2016 Share Posted July 4, 2016 Please post the file. Does the reference show up in the list on the other machines? Quote Link to comment Share on other sites More sharing options...
