jonathann3891 Posted July 6, 2016 Share Posted July 6, 2016 I have an idea for a lisp/dcl or whatever to layout rebar. So basically there will be a dialog box and you input the foundation dimensions, offsets, number of bars, rebar size, etc. and have it draw all the rebar in for you. I can see how it can get extremely complicated. My lisp knowledge is limited and I don't really know jack about DCL. Is this too complicated to accomplish or is it doable? Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 6, 2016 Share Posted July 6, 2016 Anything is doable given enough time and effort. But before I'd go reinventing (perhaps?) the wheel I would check to see if the routine already exists in some form or another. Try over at The Swamp or at the AUGI website for starters. Quote Link to comment Share on other sites More sharing options...
halam Posted July 6, 2016 Share Posted July 6, 2016 I don't think putting a lot of effort in 2D rebar detailling routines is beneficial, just to make drawings. As you mentioned. Rebar is like programming spagetti 3D, it is complicated If you want to do this effectively (not just to maing a drawing) it has to be 3D based in the first place and secendly it should be possible to export to a export format that can be fabricated (3D CAD / CAM) There is allready some good specialized rebar detailling software available (Tekla, Nemetschek). Unfortunately, not anything is put togeter DWG based. However, i find it usefull to discuss this and share some idea's with you others about how rebar is done. Kind regards Hans Civil Engineer (btw ..I only have some basic knowledge of DCL and Lisp programming but i can find my way) Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 6, 2016 Share Posted July 6, 2016 (edited) The subject of a rebar detailing lisp routine has been discussed here in the past. You might try searching for them and see what, if anything beneficial, they may have to offer. JTB World offers a rebar detailing lisp program for sale. No stated price however. http://jtbworld.com/engco-for-rebar-detailing Edited July 6, 2016 by ReMark Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 6, 2016 Share Posted July 6, 2016 Agreeing with the other guys. This is not a new idea. Already out there. I am a Revit user and I know the rebar and reinforcement tools (which are all 3D already) are very slick and can create very good outputs in no time. More importantly it's accurate, so as long as you model the structure accurately. Like Hans mentioned, not AutoCAD based though. Quote Link to comment Share on other sites More sharing options...
halam Posted July 7, 2016 Share Posted July 7, 2016 The abilities of working with rebar in Revit are limited thought. For use in civil constructions I believe in-place modelled shapes cannot be done with it. Can it, tzframpton? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 7, 2016 Share Posted July 7, 2016 The abilities of working with rebar in Revit are limited thought. For use in civil constructions I believe in-place modelled shapes cannot be done with it. Can it, tzframpton?I am in the AEC industry and have not used In-Place Families. I don't see why it wouldn't work though. I'm curious to test it. Quote Link to comment Share on other sites More sharing options...
halam Posted July 7, 2016 Share Posted July 7, 2016 Please do. I would like to know your opinion about 'valid hosts' I believe default 'AEC industry families' as you might call them can be hosts, the ones coming 'out of the Revit Box'. for any more complex geometry Dynamo seems the answer. (read: Still have to programm it...) http://core.thorntontomasetti.com/dynamo-for-rebar-is-now-available/ https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-Model/files/GUID-A620B8CD-8F8B-45F0-924E-199FBE982183-htm.html Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 7, 2016 Share Posted July 7, 2016 Hmm, that's not accurate. You can also apply rebar to Structural Columns. So... I created an In-Place Model of a regular column, and no rebar options. Did the same thing but made it a structural column and it worked. In-place Structural Column Model can add rebar. I tried it and it worked. It was a blended shape so very irregular and was still able to get it to work. Tried the same thing with an In-Place Structural Framing Model and it worked as well. Quote Link to comment Share on other sites More sharing options...
halam Posted July 7, 2016 Share Posted July 7, 2016 How simple did you shape them? Please share some pictures of geometry. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 7, 2016 Share Posted July 7, 2016 Although interesting it won't solve the OP's problem since he is using plain AutoCAD 2012. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 7, 2016 Share Posted July 7, 2016 How simple did you shape them?Please share some pictures of geometry. Simple. As in, I just placed one just to see if it would or not. I did not try at all manipulating it. Although interesting it won't solve the OP's problem since he is using plain AutoCAD 2012.Side topics. It happens. Quote Link to comment Share on other sites More sharing options...
jonathann3891 Posted July 7, 2016 Author Share Posted July 7, 2016 Simple. As in, I just placed one just to see if it would or not. I did not try at all manipulating it. Side topics. It happens. No worries I downloaded OpenDCL and started designed the DCL, But struggling with everything else. The tutorial is vague in areas and the staff on the forums isn't very helpful. Anyone here use OpenDCL? Just playing with getting the lisp to call up the DCL, I can get it to show but I cant get the slide to load. Tutorial doesnt cover that and no useful info on the forums. This project may be way beyond my skill level already Here is a glimpse of my DCL *Not Finished* Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted July 8, 2016 Share Posted July 8, 2016 @ jonathann3891: Are referring to this?: http://www.opendcl.com/forum/index.php?topic=2303.0 Quote Link to comment Share on other sites More sharing options...
jonathann3891 Posted July 8, 2016 Author Share Posted July 8, 2016 Thats one I was looking at Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted July 9, 2016 Share Posted July 9, 2016 @ jonathann3891: If you are unable to finish the OpenDCL beginners tutorial because there are sections you do not understand you should ask questions on the OpenDCL forum. Without the basic knowledge that you gain from this tutorial, you will have a hard time understanding the help, which I consider to be excellent, that is being offered. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 10, 2016 Share Posted July 10, 2016 Like others there is software out there and it's been around for say 20 years to do plain 2D structural detailing, it's all dcl driven answer questions select sizes etc and splat done. have a look at Strucplus it's an Aussie product but pretty sure sold with US and British libraries. The cost savings is tremendous start saving money from day one. I would do the dcl last get the object drawn first correct either with dummy variables set or just answer questions. Have you done the lisp part does it produce plan side front ? Post a dwg is always a good idea lets others say I have that and will share. Reading again your dcl should have lookup lists for rebars standard details like hook radius etc Quote Link to comment Share on other sites More sharing options...
iconeo Posted July 11, 2016 Share Posted July 11, 2016 I find that having a good library of parts in the tool palette works well for my firm as it allows for maximum flexibility. http://www.cadtutor.net/forum/showthread.php?93337-HELP-Stretching-and-Shrinking-problem Quote Link to comment Share on other sites More sharing options...
