Kowal Posted July 7, 2016 Posted July 7, 2016 In Civil 3D 2010 I used this function to retrieve data COGO points. In 2014 Civil function returns nil. (setq acadObject (vlax-get-acad-object)) (princ acadObject) (setq acadDocument (vla-get-ActiveDocument acadObject)) (setq mSpace (vla-get-ModelSpace acadDocument)) (print mSpace) (setq lst nil) (vlax-for ent mSpace (if (equal (vla-get-ObjectName ent) "AeccDbCogoPoint") (progn (setq enm (vlax-vla-object->ename ent)) (setq obj (vlax-ename->vla-object enm)) (setq nbr (vlax-get obj 'Number)) (setq coo (vlax-get obj 'Location)) (setq coor (mapcar '(lambda (%) (rtos % 2 3)) (list (cadr coo) (car coo) (caddr coo)))) (setq lst (append lst (list (append (list nbr) coor)))) ) ) ) How to get the properties COGO? Quote
Hippe013 Posted July 7, 2016 Posted July 7, 2016 Kowal, This is quickly put together, but should be what you are looking for. (defun c:test ( / ss n obj nbr coo coor lst) (setq ss (ssget "x" '((0 . "AECC_COGO_POINT")))) (setq n 0) (repeat (sslength ss) (setq obj (vlax-ename->vla-object (ssname ss n))) (setq nbr (vlax-get-property obj 'Number)) (setq coo (vlax-safearray->list (vlax-variant-value (vlax-get-property obj 'Location)))) (setq coor (mapcar '(lambda (%) (rtos % 2 3))(list (cadr coo)(car coo)(caddr coo)))) (setq lst (append lst (list (append (list nbr) coor)))) (setq n (+ n 1)) ) (princ (strcat "\n" (vl-princ-to-string lst))) (princ) ) regards, hippe013 Quote
