ktbjx Posted July 9, 2016 Posted July 9, 2016 Can someone help me make a LISP??? to select LINEs, input elevations and devide those elevations depending on how many lines are selected, and put it as start Z and end Z... We are making a topography map and we use LINE because it has 2 Z's (Start Z and End Z ). i included a sample... im sorry i cannot duplicate the map we are doing at work so i just made an example of what I needed... as you will see on the sample, i have: 5 lines connected, from Elevation 1 to 10 every start Z and End Z is different, but you will notice what i mean... is there a way to make a lisp out of it??? sampleline.dwg Quote
ktbjx Posted July 10, 2016 Author Posted July 10, 2016 please help me?? i have some code that copy Y to Z, maybe someone could help me change it so i can input 2 numbers, and the lisp do the rest? (defun c:test ( / ss n i e el start_point End_point new_start_point new_End_point ) (setq ss (ssget "_:L" '((0 . "LINE")))) (setq i 0) (setq n (sslength ss)) (while (< i n) (setq e (ssname ss i)) (setq el (entget e)) (setq start_point (assoc 10 el)) (setq new_start_point (list 10 (cadr start_point) (caddr start_point) (caddr start_point))) (setq el (subst new_start_point start_point el)) (setq End_point (assoc 11 el)) (setq new_End_point (list 11 (cadr End_point) (caddr End_point) (caddr End_point))) (setq el (subst new_End_point End_point el)) (entmod el) (setq i (+ 1 i)) ) (princ) ) Quote
ktbjx Posted July 10, 2016 Author Posted July 10, 2016 please???? ANYONE??? how can i change the list (start_point and End_point )??? even if i make it itoa or rtos, its still error, so please someone point me on what im doint wrong? Quote
BIGAL Posted July 11, 2016 Posted July 11, 2016 A few problems starting with all lines at z=0 pick all so know how many therfore can add Z now it does not work as the creation order would control the z value so end up with 0 1 5 6 3 4. I would make a pline use any of the get co-ords of a pline lisps that are here and then using this list of co-ords add the correct z increment make the lines or create a new 3dpline. ; pline co-ords example ; By Alan H (defun getcoords (ent) (vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object ent) "Coordinates" ) ) ) ) (defun co-ords2xy () ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z (setq len (length co-ords)) (setq numb (/ len 2)) ; even and odd check required (setq I 0) (repeat numb (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) )) ; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 2)) ) ) ; program starts here (setq co-ords (getcoords (car (entsel "\nplease pick pline")))) (co-ords2xy) ; list of 2d points making pline are saved in co-ordsxy Quote
