+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Forum Newbie
    Using
    Plant 3D 2017
    Join Date
    Jul 2016
    Posts
    3
    Default P&ID Instrument tags
    We have just updated from Plant 3D 2014 to Plant 3d 2017
    When we try to use the Instrument symbols in P&id 2017 it wont allow input of the information, it will allow a tag to be assigned and then the information is put in the bubble but you also have the assigned tag now which has to be deleted each time.
    This work perfectly in 2014
  2. #2
    Forum Newbie
    Using
    AutoCAD 2017
    Join Date
    Jul 2016
    Posts
    1
    Default
    We were experiencing the same issue, it worked fine in the 2015 version but, then we skipped ahead to 2017 and well ... anyhow found an answer on another forum Arch-Pub.com, to quote dave.wolfe "Go to project setup, P&ID drawing settings, class definitions, instrumentation. Uncheck the read only properties for the loop function and area properties. I've seen those periodically set to read only by the program." Hope it helps ....
  3. #3
    Forum Newbie
    Using
    Plant 3D 2017
    Join Date
    Jul 2016
    Posts
    3
    Default
    Hi and thanks for your reply.
    I have taken off the read only in the type, loop and area properties.
    This does fix the problem but these properties are read only in 2014.
Similar Threads
  1. Can not add tags
    By SLW210 in forum News, Announcements & FAQ
    Last Post: 26th Sep 2013, 06:24 pm
  2. Thank you Tags
    By Steve_wright in forum Feedback
    Last Post: 17th Nov 2010, 10:07 pm
  3. Annotative Tags
    By Rhayes in forum AutoCAD General
    Last Post: 10th Jun 2008, 08:08 pm
  4. Help with Tags...or?
    By Cutter in forum AutoCAD General
    Last Post: 11th Apr 2006, 03:41 pm
  5. Instrument Specification question
    By Linque in forum AutoCAD Beginners' Area
    Last Post: 14th Jan 2005, 03:09 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
