Combine two LISPs to one
verb222
Hi, I need help. I would like to make new LISP from existing two that I found.
Fist one delivers selection set (according to attribute value) that should be used by second one (changing layer of selected objects).
I think it is trivial, but I don't know how to do it. I gave it some time on google, but learned nothing.
I wolud like not to select anything during execution.
I'll change layer names on my-own later in code (this is first step od my idea of global layer change for lots of same attributes (with different specific attribute value).
1.
(defun c:attselect ( / ss2 ss tag val n na)
(setq ss2 (ssadd))
(sssetfirst nil nil)
(princ "\nSelect blocks containing attributes.")
(if (setq ss (ssget '((0 . "INSERT") (66 . 1))))
    (setq tag "COLOR"
          val "OR (1)"
    );setq
    (if (equal tag "")
        (setq tag "*")
    );if
    (if (equal val "")
        (setq val "*")
    );if
    (setq n 0)
    (repeat (sslength ss)
    (setq na (ssname ss n))
    (if (sample_att_match na tag val)
        (setq ss2 (ssadd na ss2))
    );if
    (setq n (+ n 1));setq
    );repeat
    (if (equal (getvar "cmdnames")  "")
        (sssetfirst ss2 ss2)
        (command ss2)
    );if
   );progn then
);if
);defun c:attselect
(defun sample_att_match ( na tag val / e1 a b flag)
(while (and (setq na (entnext na))
            (setq e1 (entget na))
            (not (equal (cdr (assoc 0 e1)) "SEQEND"))
            (not flag)
       );and
  (if (equal (cdr (assoc 0 e1)) "ATTRIB")
       (setq a (cdr (assoc 2 e1)) ;2 is tag
             b (cdr (assoc 1 e1)) ;1 is value
       );setq
       (if (and a
                (wcmatch a tag)
                b
                (wcmatch b val)
           );and
           (setq flag T);then jump out of the loop
       );if
      );progn then attrib
  );if
 );while
flag
);defun sample_att_match
(princ "\nType ATTSELECT to run")
I made change to original code (tag "COLOR", val "OR (1)") that I found somewhere.
2.
; Changes selected objects to Layer PL1
(defun c:setpl1 ()
 (tolayer
   (ssget "_:L") ;;selection
   "PL1"         ;;Layer
(defun tolayer ( ss lay / i e )
 ;;; ss - pickset
 ;;; lay -layer name
   (entmod
     (subst
       (cons 8 lay)
       (assoc 8 (entget (setq e (ssname ss (setq i (1- i))))))
       (entget e)
This code is found on this forum: http://www.cadtutor.net/forum/showthread.php?67438-LISP-to-move-selected-objects-to-a-specified-layer
published by VVA.
Thanx him, and creator of first code (unknown).
Thanx to the future "combiner" :)
a couple of changes
not tested
(defun c:attselect ( / ss2 tag val n na) ss has been removed so makes it a global variable
ignore setpl1
(defun c:test ()
(c:attselect)
(setq lay "PL1")
(defun tolayer ( ss lay / i e ) ;ignore setpl1
Edited by SLW210
fixed code tag
Hmm.. I've haven't been successful implementing your's advises. I have lack of knowledge. I've been trying, adding, permutating, experimenting, I've been reading AlfaLISP, JeffryLISP... Couldn't find topic related to "combining". I don't understand general logic of executing different functions in one code (in one *.lsp).
Please, can you do it for me, I'll try to gain knowledge from it, not just use it :)
Hi, I decided to read a book first. I did learned something, lots of things are more clear now... and I made code work. Please keep in mind that I am beginner in LISP, for now I am just happy when code works :).
It seems to me that variable ss2 should be global, because I need that selection set in tolayer function. This way it works.
I need further help, every comment is helpful. I feel like student again (cannot get professor consultation without personel preparation on topic :)).
I attached Example1.dwg to easier test.
Please, take look at comments in code.
Here's the code:
;|combining attselect and layer change.
c:test- it works!
- at the end should do this: select all blocks in drawing, filter it by attribute value "OR (1)", change layer of those to PURPLE
- main command that combines two of those:
	c:attselect - selects all blocks in layer GREEN with attribute value "OR (1)"
	c:tolay - it changes selection layer to PURPLE
idea1: I wish that I dont need to select manualy whole drawing with mouse. I wish LISP do it without me.
idea2: Later... :-)	|;
;final combining command
(defun c:test ()
(c:attselect)
(c:tolay)
;makes selection (only blocks within layer GREEN)
(defun c:attselect ( / ss tag val n na)
(setq ss2 (ssget "all" '((8 . "GREEN")(0 . "INSERT"))))
comment for line above
this is original line in original command: (setq ss2 (ssadd))
I'm trying to make this selection automatic (without mouse input of selecting all
I don't know how!!!
    (setq tag "COLOR"
          val "OR (1)"
    );setq
    (if (equal tag "")
        (setq tag "*")
    );if
    (if (equal val "")
        (setq val "*")
    );if
    (setq n 0)
    );if
    );repeat
        (command ss2)
    );if
   );progn then
);if
);defun c:attselect
            (not flag)
       );and
       );setq
       (if (and a
                (wcmatch a tag)
                b
                (wcmatch b val)
           );and
       );if
      );progn then attrib
  );if
 );while
flag
; changes layer of selection provided by attselect
(defun c:tolay ()
 (command "_.chprop" (eval ss2) "" "_layer" "PURPLE" "")
