gedu Posted July 21, 2016 Share Posted July 21, 2016 In the file TEXT-POINT-ZERO.dwg zeta points is zero . Is there any Lisp program to the value of the text by selecting the point globally or by layer ? In TEXT-POINT-OK.dwg file it is as it should be ended . Thank you TEXT-POINT-ZERO.dwg TEXT-POINT-OK.dwg Quote Link to comment Share on other sites More sharing options...
broncos15 Posted July 21, 2016 Share Posted July 21, 2016 Here is something to get you started. I left the text portion empty for you to practice. Let me know if you need help on it. (defun c:test (/ ss dxf10 elev cnt *error*) (defun *error* (msg) (if (not (member msg '("Function cancelled" "quit / exit abort")) ) (princ (strcat "\nError: " msg)) ) (princ) ) (if (setq ss (LM:ssget "\nSelect Points to Add Elevation Text: " '(((0 . "POINT"))) ) ) (progn (setq cnt 0) (repeat (sslength ss) (setq dxf10 (cdr (assoc 10 (entget (ssname ss cnt)))) elev (caddr dxf10) cnt (+ cnt 1) ) ;;; Now you just need to add in the text code, it will be based on what offset from the point you ;;; want ) ) ) (princ) ) ;; ssget - Lee Mac ;; A wrapper for the ssget function to permit the use of a custom selection prompt ;; msg - [str] selection prompt ;; arg - [lst] list of ssget arguments (defun LM:ssget (msg arg / sel) (princ msg) (setvar 'nomutt 1) (setq sel (vl-catch-all-apply 'ssget arg)) (setvar 'nomutt 0) (if (not (vl-catch-all-error-p sel)) sel ) ) Quote Link to comment Share on other sites More sharing options...
gedu Posted July 22, 2016 Author Share Posted July 22, 2016 Sorry , I need help . If the lisp was finished would be ideal . Thank you. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 22, 2016 Share Posted July 22, 2016 Quickly patched together (defun c:test (/ ss dxf10 elev cnt *error*) (defun *error* (msg) (if (not (member msg '("Function cancelled" "quit / exit abort")) ) (princ (strcat "\nError: " msg)) ) (princ) ) (alert "Select Points to Add Elevation Text: ") (if (setq ss (ssget (list(cons 0 "POINT")))) (progn (setq cnt 0) (repeat (sslength ss) (setq dxf10 (cdr (assoc 10 (entget (ssname ss cnt)))) elev (caddr dxf10) cnt (+ cnt 1) ) (command "Text" dxf10 "" "" (rtos elev 2 3)) ;;; Now you just need to add in the text code, it will be based on what offset from the point you ;;; want ) ) ) (princ) ) ;; ssget - Lee Mac ;; A wrapper for the ssget function to permit the use of a custom selection prompt ;; msg - [str] selection prompt ;; arg - [lst] list of ssget arguments (defun LM:ssget (msg arg / sel) (princ msg) (setvar 'nomutt 1) (setq sel (vl-catch-all-apply 'ssget arg)) (setvar 'nomutt 0) (if (not (vl-catch-all-error-p sel)) sel ) ) Quote Link to comment Share on other sites More sharing options...
gedu Posted July 22, 2016 Author Share Posted July 22, 2016 The program selects the points, but the text value is not transferred . I must do something else? Regards. Quote Link to comment Share on other sites More sharing options...
BKT Posted July 23, 2016 Share Posted July 23, 2016 You might want to take a look at the "Similar Threads" at the bottom of this page, specifically the "Point from Text". Quote Link to comment Share on other sites More sharing options...
