gedu Posted July 21, 2016 Posted July 21, 2016 In the file TEXT-POINT-ZERO.dwg zeta points is zero . Is there any Lisp program to the value of the text by selecting the point globally or by layer ? In TEXT-POINT-OK.dwg file it is as it should be ended . Thank you TEXT-POINT-ZERO.dwg TEXT-POINT-OK.dwg Quote
broncos15 Posted July 21, 2016 Posted July 21, 2016 Here is something to get you started. I left the text portion empty for you to practice. Let me know if you need help on it. (defun c:test (/ ss dxf10 elev cnt *error*) (defun *error* (msg) (if (not (member msg '("Function cancelled" "quit / exit abort")) ) (princ (strcat "\nError: " msg)) ) (princ) ) (if (setq ss (LM:ssget "\nSelect Points to Add Elevation Text: " '(((0 . "POINT"))) ) ) (progn (setq cnt 0) (repeat (sslength ss) (setq dxf10 (cdr (assoc 10 (entget (ssname ss cnt)))) elev (caddr dxf10) cnt (+ cnt 1) ) ;;; Now you just need to add in the text code, it will be based on what offset from the point you ;;; want ) ) ) (princ) ) ;; ssget - Lee Mac ;; A wrapper for the ssget function to permit the use of a custom selection prompt ;; msg - [str] selection prompt ;; arg - [lst] list of ssget arguments (defun LM:ssget (msg arg / sel) (princ msg) (setvar 'nomutt 1) (setq sel (vl-catch-all-apply 'ssget arg)) (setvar 'nomutt 0) (if (not (vl-catch-all-error-p sel)) sel ) ) Quote
gedu Posted July 22, 2016 Author Posted July 22, 2016 Sorry , I need help . If the lisp was finished would be ideal . Thank you. Quote
BIGAL Posted July 22, 2016 Posted July 22, 2016 Quickly patched together (defun c:test (/ ss dxf10 elev cnt *error*) (defun *error* (msg) (if (not (member msg '("Function cancelled" "quit / exit abort")) ) (princ (strcat "\nError: " msg)) ) (princ) ) (alert "Select Points to Add Elevation Text: ") (if (setq ss (ssget (list(cons 0 "POINT")))) (progn (setq cnt 0) (repeat (sslength ss) (setq dxf10 (cdr (assoc 10 (entget (ssname ss cnt)))) elev (caddr dxf10) cnt (+ cnt 1) ) (command "Text" dxf10 "" "" (rtos elev 2 3)) ;;; Now you just need to add in the text code, it will be based on what offset from the point you ;;; want ) ) ) (princ) ) ;; ssget - Lee Mac ;; A wrapper for the ssget function to permit the use of a custom selection prompt ;; msg - [str] selection prompt ;; arg - [lst] list of ssget arguments (defun LM:ssget (msg arg / sel) (princ msg) (setvar 'nomutt 1) (setq sel (vl-catch-all-apply 'ssget arg)) (setvar 'nomutt 0) (if (not (vl-catch-all-error-p sel)) sel ) ) Quote
gedu Posted July 22, 2016 Author Posted July 22, 2016 The program selects the points, but the text value is not transferred . I must do something else? Regards. Quote
BKT Posted July 23, 2016 Posted July 23, 2016 You might want to take a look at the "Similar Threads" at the bottom of this page, specifically the "Point from Text". Quote
