I have done a little bit of Lisping but this one is beyond me so I am hoping someone can help. I have been looking for a way to do the following:
  • Select first block (SL-Dev) and grab the value of the attribute tag ID_1 (this stays the same for multiple selections)
  • Select second block (SL-Con) and grab the value of attribute tag IN_1
  • Place both values with a space between (ID_1 IN_1) and put that new value back into the second block (SL-Con) with the attribute tag NEAR
  • I would then like to continue this process by clicking on multiple SL-Con blocks and use its tag IN_1 to combine with the ORIGINAL SL_DEV tag ID_1
Seems pretty tricky to me but any help would be appreciated
Untested...
(defun c:ID_1-sour+IN_1-dest->NEAR-dest ( / s b1 sourval1 b2 sourval2 destval )
 (vl-load-com)
 (prompt "\nPick (SL-Dev) block reference...")
 (setq s (ssget "_+.:E:S" '((0 . "INSERT") (66 . 1))))
 (while (or (not s) (vlax-property-available-p (setq b1 (vlax-ename->vla-object (ssname s 0))) 'Path) (/= (vla-get-effectivename b1) "SL-Dev"))
   (prompt "\nMissed or wrong block reference pick or picked xref... Try picking (SL-Dev) block reference again...")
 (foreach att (append (vlax-invoke b1 'getattributes) (vlax-invoke b1 'getstaticattributes))
   (if (= (vla-get-tagstring att) "ID_1")
     (setq sourval1 (vla-get-textstring att))
 (while t
   (prompt "\nPick (SL-Con) block reference... ESC to terminate and finish picking (SL-Con) block references...")
   (setq s (ssget "_+.:E:S:L" '((0 . "INSERT") (66 . 1))))
   (while (or (not s) (vlax-property-available-p (setq b2 (vlax-ename->vla-object (ssname s 0))) 'Path) (/= (vla-get-effectivename b2) "SL-Con"))
     (prompt "\nMissed or wrong block reference pick or picked xref... Try picking (SL-Con) block reference again...")
   (foreach att (append (vlax-invoke b2 'getattributes) (vlax-invoke b2 'getstaticattributes))
     (if (= (vla-get-tagstring att) "IN_1")
       (setq sourval2 (vla-get-textstring att))
   (setq destval (strcat sourval1 " " sourval2))
     (if (= (vla-get-tagstring att) "NEAR")
       (vla-put-textstring att destval)
To give you picture what should it look like...
As I said beyond me...
I did load it and run it however, and this is what I got after I selected the SL-DEV block (it is dynamic if that makes a difference).
Select objects:
; error: ActiveX Server returned the error: unknown name: "GETSTATICATTRIBUTES"
Replace (append (vlax-invoke [b1/b2] 'getattributes) (vlax-invoke [b1/b2] 'getstaticattributes))... with (append (vlax-invoke [b1/b2] 'getattributes) (vlax-invoke [b1/b2] 'getconstantattributes)) in all occurrencies in posted code... I don't have time, you'll have to debugg it alone...
Edited by marko_ribar
message changed...
Try the following untested code:
([color=BLUE]defun[/color] c:combatt ( [color=BLUE]/[/color] ent id1 idx in1 sel )
   ([color=BLUE]while[/color]
       ([color=BLUE]progn[/color] ([color=BLUE]setvar[/color] 'errno 0) ([color=BLUE]setq[/color] ent ([color=BLUE]car[/color] ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect SL-DEV block <exit>: "[/color])))
           ([color=BLUE]cond[/color]
               (   ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color])
               (   ([color=BLUE]null[/color] ent) [color=BLUE]nil[/color])
               (   ([color=BLUE]/=[/color] [color=MAROON]"INSERT"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]entget[/color] ent))))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nSelected object is not a block."[/color])
               (   ([color=BLUE]/=[/color] [color=MAROON]"SL-DEV"[/color] ([color=BLUE]strcase[/color] (LM:al-effectivename ent)))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nSelected block is not an \"SL-DEV\" block."[/color])
               (   ([color=BLUE]not[/color] ([color=BLUE]setq[/color] id1 (LM:getattributevalue ent [color=MAROON]"ID_1"[/color])))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nBlock does not contain \"ID_1\" attribute."[/color])
   ([color=BLUE]if[/color]
       ([color=BLUE]and[/color] id1
           ([color=BLUE]setq[/color] sel
               ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color]
                   ([color=BLUE]list[/color] '(0 . [color=MAROON]"INSERT"[/color]) '(66 . 1)
                       ([color=BLUE]cons[/color] 2
                           ([color=BLUE]apply[/color] '[color=BLUE]strcat[/color]
                               ([color=BLUE]cons[/color] [color=MAROON]"SL-CON"[/color]
                                   ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( x ) ([color=BLUE]strcat[/color] [color=MAROON]",`"[/color] x))
                                       (LM:getanonymousreferences [color=MAROON]"SL-CON"[/color])
       ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] idx ([color=BLUE]sslength[/color] sel))
           ([color=BLUE]if[/color] ([color=BLUE]setq[/color] ent ([color=BLUE]ssname[/color] sel ([color=BLUE]setq[/color] idx ([color=BLUE]1-[/color] idx)))
                     in1 (LM:getattributevalue ent [color=MAROON]"IN_1"[/color])
               (LM:setattributevalue ent [color=MAROON]"NEAR"[/color] ([color=BLUE]strcat[/color] id1 in1))
   ([color=BLUE]princ[/color])
[color=GREEN];; Get Anonymous References  -  Lee Mac[/color]
[color=GREEN];; Returns the names of all anonymous references of a block.[/color]
[color=GREEN];; blk - [str] Block name/wildcard pattern for which to return anon. references[/color]
([color=BLUE]defun[/color] LM:getanonymousreferences ( blk [color=BLUE]/[/color] ano def lst rec ref )
   ([color=BLUE]setq[/color] blk ([color=BLUE]strcase[/color] blk))
   ([color=BLUE]while[/color] ([color=BLUE]setq[/color] def ([color=BLUE]tblnext[/color] [color=MAROON]"block"[/color] ([color=BLUE]null[/color] def)))
           ([color=BLUE]and[/color] ([color=BLUE]=[/color] 1 ([color=BLUE]logand[/color] 1 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 70 def))))
               ([color=BLUE]setq[/color] rec
                           ([color=BLUE]assoc[/color] 330
                                   ([color=BLUE]tblobjname[/color] [color=MAROON]"block"[/color]
                                       ([color=BLUE]setq[/color] ano ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 def)))
                   ([color=BLUE]not[/color] ([color=BLUE]member[/color] ano lst))
                   ([color=BLUE]setq[/color] ref ([color=BLUE]assoc[/color] 331 rec))
                       ([color=BLUE]entget[/color] ([color=BLUE]cdr[/color] ref))
                       ([color=BLUE]wcmatch[/color] ([color=BLUE]strcase[/color] (LM:al-effectivename ([color=BLUE]cdr[/color] ref))) blk)
                   ([color=BLUE]setq[/color] lst ([color=BLUE]cons[/color] ano lst))
               ([color=BLUE]setq[/color] rec ([color=BLUE]cdr[/color] ([color=BLUE]member[/color] ([color=BLUE]assoc[/color] 331 rec) rec)))
   ([color=BLUE]reverse[/color] lst)
[color=GREEN];; Effective Block Name  -  Lee Mac[/color]
[color=GREEN];; ent - [ent] Block Reference entity[/color]
([color=BLUE]defun[/color] LM:al-effectivename ( ent [color=BLUE]/[/color] blk rep )
   ([color=BLUE]if[/color] ([color=BLUE]wcmatch[/color] ([color=BLUE]setq[/color] blk ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 ([color=BLUE]entget[/color] ent)))) [color=MAROON]"`**"[/color])
               ([color=BLUE]setq[/color] rep
                   ([color=BLUE]cdadr[/color]
                       ([color=BLUE]assoc[/color] -3
                                           ([color=BLUE]tblobjname[/color] [color=MAROON]"block"[/color] blk)
                              '([color=MAROON]"acdbblockrepbtag"[/color])
               ([color=BLUE]setq[/color] rep ([color=BLUE]handent[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 1005 rep))))
           ([color=BLUE]setq[/color] blk ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 ([color=BLUE]entget[/color] rep))))
   blk
[color=GREEN];; Get Attribute Value  -  Lee Mac[/color]
[color=GREEN];; Returns the value held by the specified tag within the supplied block, if present.[/color]
[color=GREEN];; blk - [ent] Block (Insert) Entity Name[/color]
[color=GREEN];; tag - [str] Attribute TagString[/color]
[color=GREEN];; Returns: [str] Attribute value, else nil if tag is not found.[/color]
([color=BLUE]defun[/color] LM:getattributevalue ( blk tag [color=BLUE]/[/color] enx )
   ([color=BLUE]if[/color] ([color=BLUE]=[/color] [color=MAROON]"ATTRIB"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]setq[/color] enx ([color=BLUE]entget[/color] ([color=BLUE]setq[/color] blk ([color=BLUE]entnext[/color] blk)))))))
       ([color=BLUE]if[/color] ([color=BLUE]=[/color] ([color=BLUE]strcase[/color] tag) ([color=BLUE]strcase[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 enx))))
           ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 1 enx))
           (LM:getattributevalue blk tag)
[color=GREEN];; Set Attribute Value  -  Lee Mac[/color]
[color=GREEN];; Sets the value of the first attribute with the given tag found within the block, if present.[/color]
[color=GREEN];; val - [str] Attribute Value[/color]
[color=GREEN];; Returns: [str] Attribute value if successful, else nil.[/color]
([color=BLUE]defun[/color] LM:setattributevalue ( blk tag val [color=BLUE]/[/color] enx )
           ([color=BLUE]if[/color] ([color=BLUE]entmod[/color] ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] 1 val) ([color=BLUE]assoc[/color] 1 enx) enx))
                   ([color=BLUE]entupd[/color] blk)
                   val
           (LM:setattributevalue blk tag val)
The above uses my Attribute Functions & Get Anonymous References function.
Lee, you are the man!!! Works like a charm thank you!
Excellent - you're welcome!
  • 1 year later...
Lee, we have been using the above for almost a year not (THANKS AGAIN) we have found a couple items that we would like to change. I tried a couple things but was unsuccessful so I am hoping you or someone else can help with the changes.
Originally we had two blocks to draw information from SL-Dev and SL-Con, what we are looking for now is to be able to select SL-Dev or SL-Dev2 for the first selection set and SL-Con, SL-Con2, SL-Con3, SL-Con4 for the second selection set. The attribute tags for SL-Dev and SL-Dev2 are the same as are the tags for the SL-Con blocks.
I can't seem to figure out how to increase the selection sets so any help would be appreciated.
What we are looking for now is to be able to select SL-Dev or SL-Dev2 for the first selection set and SL-Con, SL-Con2, SL-Con3, SL-Con4 for the second selection set.
Change the following:
Line 12 from:
                (   (/= "SL-DEV" (strcase (LM:al-effectivename ent)))
to:
                (   (not (wcmatch (strcase (LM:al-effectivename ent)) "SL-DEV,SL-DEV2"))
Line 28 from:
                                (cons "SL-CON"
to:
                                (cons "SL-CON,SL-CON[234]"
Line 30 from:
                                        (LM:getanonymousreferences "SL-CON")
to:
                                        (LM:getanonymousreferences "SL-CON,SL-CON[234]")
Lee,
Thank you for the very quick reply, IT WORKS GREAT! Thank you so much. It was the item and list on the cons that tripped me up, I still have a lot to learn.
Thanks again!
