pmxcad Posted August 11, 2016 Posted August 11, 2016 Hello, I have a lisp that rotates the attributes from a selected block. Can it be changed that only the selected attributes rotates and not all of them. There are multiple attributes in a block and they all need a different angle. (defun c:atrot(/ blSet attLst errCount oldAng) (if(not atrot:rAng)(setq atrot:rAng 0)) (setq oldAng atrot:rAng atrot:rAng (getangle (strcat "\nSpecify rotation angle <"(angtos atrot:rAng)">: "))) (if(not atrot:rAng)(setq atrot:rAng oldAng)) (princ "<<< Select blocks to rotate attributes >>>") (setq errCount 0) (if (setq blSet(ssget '((0 . "INSERT")(66 . 1)))) (progn (setq blSet(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex blSet))))) (foreach itm blSet (setq attLst (vlax-safearray->list (vlax-variant-value (vla-GetAttributes itm)))) (foreach att attLst (if(vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Rotation(list att atrot:rAng))) (setq errCount(1+ ErrCount)) ); end if ); end foreach ); end foreach ); end progn (princ ">>> Nothing selected! <<<") ); end if (if(/= 0 errCount) (princ (strcat "\n>>> " (itoa errCount) " attributes or blocks were on locked layer! <<< ")) ); end if (princ) ); end of c:atrot Thank you in advance, PMXcad Quote
alm865 Posted August 12, 2016 Posted August 12, 2016 Are you after something like this? (defun c:atrot(/ blSet attLst errCount oldAng TagS response) (if(not atrot:rAng)(setq atrot:rAng 0)) (setq oldAng atrot:rAng atrot:rAng (getangle (strcat "\nSpecify rotation angle <"(angtos atrot:rAng)">: "))) (if(not atrot:rAng)(setq atrot:rAng oldAng)) (princ "<<< Select blocks to rotate attributes >>>") (setq errCount 0) (if (setq blSet(ssget '((0 . "INSERT")(66 . 1)))) (progn (setq blSet(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex blSet))))) (foreach itm blSet (setq attLst (vlax-safearray->list (vlax-variant-value (vla-GetAttributes itm)))) (foreach att attLst (progn (initget "Y N") (setq TagS (vlax-get-property att 'TagString)) (if (eq TagS nil) (setq response (getkword "Rotate Y/N?")) (setq response (getkword (strcat TagS " Rotate Y/N?"))) ) (if (eq response "Y") (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Rotation(list att atrot:rAng) ) ) (setq errCount(1+ ErrCount)) ); end if ); endif );end progn ); end foreach ); end foreach ); end progn (princ ">>> Nothing selected! <<<") ); end if (if(/= 0 errCount) (princ (strcat "\n>>> " (itoa errCount) " attributes or blocks were on locked layer! <<< ")) ); end if (princ) ); end of c:atrot Sorry if I've stuffed up your indenting.... Quote
alm865 Posted August 12, 2016 Posted August 12, 2016 Just re-read your post, this asks for angles for each object: (defun c:atrot(/ blSet attLst errCount oldAng TagS response) (if(not atrot:rAng)(setq atrot:rAng 0)) ;;; (setq oldAng atrot:rAng ;;; atrot:rAng ;;; (getangle ;;; (strcat "\nSpecify rotation angle <"(angtos atrot:rAng)">: "))) ;;; (if(not atrot:rAng)(setq atrot:rAng oldAng)) (princ "<<< Select blocks to rotate attributes >>>") (setq errCount 0) (if (setq blSet(ssget '((0 . "INSERT")(66 . 1)))) (progn (setq blSet(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex blSet))))) (foreach itm blSet (setq attLst (vlax-safearray->list (vlax-variant-value (vla-GetAttributes itm)))) (foreach att attLst (progn (initget "Y N") (setq TagS (vlax-get-property att 'TagString)) (if (eq TagS nil) (setq response (getkword "Rotate Y/N?")) (setq response (getkword (strcat TagS " Rotate Y/N?"))) ) (if (eq response "Y") (progn (setq atrot:rAng (getangle (strcat "\nSpecify rotation angle <"(angtos atrot:rAng)">: "))) (if (eq nil atrot:rAng) (setq atrot:rAng 0) ) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Rotation(list att atrot:rAng) ) ) (setq errCount(1+ ErrCount)) ); end if );end progn ); endif );end progn ); end foreach ); end foreach ); end progn (princ ">>> Nothing selected! <<<") ); end if (if(/= 0 errCount) (princ (strcat "\n>>> " (itoa errCount) " attributes or blocks were on locked layer! <<< ")) ); end if (princ) ); end of c:atrot Quote
pmxcad Posted August 12, 2016 Author Posted August 12, 2016 Good job alm865. Almost perfect. Can it be made simpler? ATROT -> angle -> pick attribute -> done. And for the other attributes i wil do the same....running ATROT. There are blocks with a lot of attributtes, like 10. And it could be that a attribute is the last one. By selecting a attribute for rotating.i scip the other attributes. PMXcad Quote
alm865 Posted August 13, 2016 Posted August 13, 2016 Well there's lots of ways to do it. If it was me I'd do a first pass with your script and create a list of attributes. Send the list to a 'list box in a dialog' for user selection (i.e. create a DCL file). The user returns the list and you check that each item is a member of the user's selection. Kind of like how the new 'laydel' command works if you choose selection by name. If I get some time I'll post an example unless someone beats me to it with a better way ;-) Quote
pmxcad Posted August 14, 2016 Author Posted August 14, 2016 Okay Alm865, it's solved. I found a lisp in my lisp database. This does exactly what I want and more. See code: ;* Variables ans = given answer to what to change * ;* tmp = temporary storage * ;* alist = storage of separate selections (check list) * ;* pt = storage for point selections * ;* sset = selection set storage ( check for entity ) * ;* cnt = storage for counter vs. string length * ;************************************************************************* ; (defun c:chatt ( / cnt ans tmp alist pt sset value angle style layer color hgt pos) (setq ans "") (setq tmp " ") (setq alist (list "")) (While (/= tmp "") ; Continue if user ; gives us an answer. (prompt "\nChange what?\nValue, Angle,") (prompt " Style, Layer, Color, Height, Position:"); Long eh? (if (> (strlen ans) 0) (progn (prompt "\nCurrent[") ; Display the current (prompt ans) ; list if available. (prompt "]:") ) ) (setq tmp (strcase (substr (getstring) 1 1))) (if (AND (or (= tmp "V")(= tmp "A")(= tmp "S")(= tmp "L") (= tmp "C")(= tmp "H")(= tmp "P")) (= nil (member tmp alist)) ) ; If the answer is in the (progn ; group and not in the (setq ans(strcat ans tmp)) ; check list add it! (setq alist (append alist (list tmp))) ) ) ) (if (= ans "")(setq ans "VASLCHP")) ; If the user doesn't (setq cnt 1) ; us an option force (setq value nil) ; all of them! (setq angle nil) (setq style nil) ; Set all the variables (setq layer nil) ; to nil! (setq color nil) ; I'm not very trusting! (setq hgt nil) (setq pos nil) (While (/= "" (setq tmp (substr ans cnt 1))) ; Check for options and ; get the values. (if (= tmp "V") (setq value (getstring "\nNew Value for attributes: ")) ) (if (= tmp "A") (setq angle (* 180 (/ (getangle "\nNew angle for attributes: ") pi))) ) (if (= tmp "S") (setq style (getstring "\nNew style for attributes: ")) ) (if (= tmp "L") (setq layer (getstring "\nNew layer for attributes: ")) ) (if (= tmp "C") (setq color (getstring "\nNew color for attributes: ")) ) (if (= tmp "H") (setq hgt (getdist "\nNew height for attributes: ")) ) (if (= tmp "P")(setq pos 1)) (setq cnt (+ cnt 1)) ) (setvar "cmdecho" 0) (setq pt (getpoint "\nSelect Attribute: ")) ; As long as we get a (while pt ; point value! (if (setq sset (ssget pt)) ; Check for an entity! (progn (if (= nil (assoc 66 (entget (ssname sset 0)))) (progn ; If it does not have ; Attributes worry! (prompt "\nNot An Attributed Block") (setq sset nil) ) ) ) (progn ; If you dont find (prompt "\nNo Entity Found") ; an entity at the (setq sset nil) ; given location ) ; worry! ) (if (and pt sset) (progn ; If all is well, (command ".attedit" "" "" "" "" pt "" ) ; Start the ATTEDIT (if value (command "v" "r" value)) ; function and do (if angle (command "a" angle)) ; each one that was (if style (command "s" style)) ; requested and (if layer (command "l" layer)) ; that has a value. (if color (command "c" color )) (if hgt (command "h" hgt )) ; If the position (if pos ; was requested, (progn ; give an additional (Prompt "\n New Position: ") ; prompt since we (command "p" pause ) ; turned off the ) ; command echo! ) (command "") ; Terminate the ) ; command. ) (setq pt (getpoint "\nSelect Attribute: ")) ; Get a new point! ) ) ;/* End of File */ still thanks for your time PMXcad Quote
BIGAL Posted August 15, 2016 Posted August 15, 2016 This post may have some thing useful http://www.cadtutor.net/forum/showthread.php?97667-Auto-rotaing-text-to-any-UCS Quote
