Question : Select objects on the reference file to be Reloaded
Hello !
I see a lisp about reload xref , I find a question.
(Defun C:xref_reload ( / rnames i e elist rname)
       (setvar "cmdecho" 0)
         (princ "\nSelect  objects on the reference file to be Reloaded:")
         (if (setq SS (ssget))
                             (setq Rnames "")
                             (repeat
                               (setq I (sslength SS))
                               (setq E (ssname SS (setq I (1- I))))
                               (setq ELIST (entget E))
                               (setq Rname (cdr (assoc 2 ELIST)))
                               (command "-xref" "R" Rname)
                               (setq Rnames (strcat Rname ", " Rnames))
                             );end repeat
                             (prompt "\nFiles have been Reloaded:")
                             (princ Rnames)
                   );end progn
         );end if
Question is : If this xref has unload . I can't see this xref in drawing. So, How do I do “Select objects on the reference file” ?
I think need a dialog show unload reference file list , select item reload from dialog.
I think can use Lee's listbox function to do. Who can help me? Thanks a million.
How get the unload xref list ?
This may be useful:
(defun ListUnloadedXrefs ( / ret)
 (vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
   (if
     (and
       (= :vlax-true (vla-get-isxref blk))
       (not (vla-get-xrefdatabase blk))
     (setq ret (cons (vla-get-name blk) ret))
 (reverse ret)
Another, using Vanilla:
(defun unloadedxrefs ( / r x )
   (while (setq x (tblnext "block" (not x)))
       (if (= 4 (logand (cdr (assoc 70 x)) 36))
           (setq r (cons (cdr (assoc 2 x)) r))
   (reverse r)
_$ (unloadedxrefs)
("xref")
This may be useful:
   (if
     (and
 (reverse ret)
Hi Roy. Thank you ,But I test , not succeed !
I use acad2011 & 2015 test , The same error:
; error: Automation Error. Description was not provided.
   (reverse r)
_$ (unloadedxrefs)
("xref")
Lee, Thank you very much! gooooooooood!!! :D
like this ? :lol:
(defun c:xr ( )
(if (unloadedxrefs)
		(foreach x (LM:listbox "Select reference file to be Reloaded" (unloadedxrefs) 1)
			(command "-xref" "R" x)
	(prompt "\nNo reference file need reload.")
Edited by DuanJinHui
Edited code
Strange. I am not sure why you are getting this.
Did you include this in your code?:
(vl-load-com)
(vl-load-com)
Hi Roy, I did.
You're welcome!
like this ? :lol:
(defun c:xr ( )
   (if (unloadedxrefs)
Yes, that would work - you could improve the efficiency slightly by storing the list of unloaded xrefs using a local variable, e.g.:
(defun c:xr ( / lst )
   (if (setq lst (unloadedxrefs))
           (foreach x (LM:listbox "Select reference file to be Reloaded" lst 1)
You're welcome!
Lee,Thank you again.Very helpful.
