ktbjx Posted August 17, 2016 Share Posted August 17, 2016 how do you export the group name of a line on excel?? i checked all (as in everything!) on dataextraction and nothing there says group Command: Specify opposite corner: Command: list 28 found LINE Layer: "ChCt_ EL 960(ASSAY) 02" Space: Model space Handle = 3921 Group = 1000 from point, X=1086.3440 Y=-1442.1871 Z= 960.0000 to point, X=1086.9695 Y=-1443.2810 Z= 960.0000 Length = 1.2601, Angle in XY Plane = 150 Delta X = 0.6255, Delta Y = -1.0939, Delta Z = 0.0000 LINE Layer: "ChCt_ EL 960(ASSAY) 02" Space: Model space Handle = 3922 Group = 1000 from point, X=1085.6364 Y=-1440.9190 Z= 960.0000 to point, X=1086.1320 Y=-1441.8325 Z= 960.0000 Length = 1.0392, Angle in XY Plane = 152 Delta X = 0.4956, Delta Y = -0.9134, Delta Z = 0.0000 LINE Layer: "ChCt_ EL 960(ASSAY) 02" Space: Model space Press ENTER to continue: Handle = 3920 Group = 1000 from point, X=1084.6116 Y=-1443.2342 Z= 960.0000 to point, X=1085.0453 Y=-1444.3133 Z= 960.0000 Length = 1.1630, Angle in XY Plane = 158 Delta X = 0.4337, Delta Y = -1.0791, Delta Z = 0.0000 LINE Layer: "ChCt_ EL 960(ASSAY) 02" Space: Model space Handle = 391f Group = 1000 from point, X=1083.9087 Y=-1441.4312 Z= 960.0000 to point, X=1084.3099 Y=-1442.4307 Z= 960.0000 Length = 1.0770, Angle in XY Plane = 158 Delta X = 0.4012, Delta Y = -0.9995, Delta Z = 0.0000 LINE Layer: "ChCt_ EL 960(ASSAY) 02" Space: Model space Handle = 391e Group = 1000 from point, X=1081.9344 Y=-1441.6970 Z= 960.0000 to point, X=1082.2560 Y=-1442.9088 Z= 960.0000 you see?? when i type list, i see the group... how can i extract that to correspond on the XYZ that was extracted Quote Link to comment Share on other sites More sharing options...
ktbjx Posted August 17, 2016 Author Share Posted August 17, 2016 yep no help Quote Link to comment Share on other sites More sharing options...
TheCADnoob Posted August 18, 2016 Share Posted August 18, 2016 yep no help This place is not a magical help machine. I have seen others try what i believe to be something similar with data extraction and had the same problem Im not sure group can be extracted using data extraction. I have used Jeffery sanders CAD 2 File lisp before. ( http://www.jefferypsanders.com/autolisp.html ) Ive also hacked it up to make it work for specific problems. If you feel like getting your hands dirty with lisp you could probably ~easily add group (assuming its a value like the others in the database) to the output list. Quote Link to comment Share on other sites More sharing options...
