Help many circle center layout rectangle and rotate rectangle
Help needed a lisp!!
1.There are many circle center and base on circle center layout rectangle(rectangle
can keyin size).
2.Then base on circle center rotate all rectangle for any angle.
Pls Help!!
Huh ? No idea just a responce for the now 48 people who has looked at this post. If you don't explain clearly no one will answer.
sample.pdf
Sorry!I attach a file for my explain .
Ok a very simple lisp task so maybe its time to have a go
A suggestion use VL-lisp as it more descriptive to what your retrieving for this project
; copy this next line to your command line and pick circle you will see the entity detail names use a vla-get-"entityname"
(vlax-Dump-Object (vlax-Ename->Vla-Object (car (entsel "pick circle"))))
: need this line at start
(vl-load-com)
1 select circle get radius and center point see dump detail above
2 draw a 4 sided pline (setq pt2 (polar pt1 0 rad)) join pt1 pt2 pt3 c
3 rotate the square (command "rotate" "L" note the drag switch
4 all done ! congrats you have done a lisp
Edited by BIGAL
(vl-load-com)
3 rotate the square (command "rotate" "L" note the /drag switch
Thanks for your reply,but I do not know how to write lisp. can you help ?
Ok
; box inside a circle by Alan H Aug 2016 using vl
(defun c:circbox ( / obj rad cen)
(setq obj (vlax-Ename->Vla-Object (car (entsel "pick circle"))))
(setq rad (vla-get-radius obj))
(setq cen (vlax-get obj 'center))
(setq pt2 (polar cen 0.0 rad))
(setq pt3 (polar pt2 (/ pi 2.0) rad))
(setq Pt4 (polar cen (/ pi 2.0) rad))
(command "pline" cen pt2 pt3 pt4 "C")
(command "rotate" "L" "" cen "drag")
(c:circbox) ; remove this later just for testing
; box inside a circle by Alan H Aug 2016 using assoc
(setq obj (entget (car (entsel "pick circle"))))
(setq rad (cdr (assoc 40 obj)))
(setq cen (cdr (assoc 10 obj)))
  • 1 month later...
Thanks BIGAL.
This lisp is for one circle, are there any way for many circles?
Do a bit of home work about using (setq ss (ssget '((0 . "Circle")))) then ssname, need to replace the entsel in code above with a repeat and loop through the selection set ss drawing the box around each circle.
This is a real common thing in lisp even just look at some of the posts in the LISP section.
If it gets to hard post again.
Sorry!!I really do not know how to write lisp,but I will try to do.
Thank you very much
Found a few minutes
(defun AH:circbox (obj / rad cen pt2 pt3 pt4)
(command "rotate" "L" "" cen (getpoint cen))
(defun c:circbox ( / x ss obj)
(setq oldsnap (getvar "osmode"))
(setvar "osmode" 0)
(setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(AH:circbox obj)
) ; repeat
(setvar "osmode" oldsnap)
) ; defun
(c:circbox)
Thank you a lot!!!
I found this lisp before, too.
I would like to change angle for all I select, so...........
Found a few minutes
(setvar "osmode" 0)
(AH:circbox obj)
) ; repeat
) ; defun
(c:circbox)
Try this
;The dtr function converts degrees to radians
;The rtd function converts radians to degrees
(defun dtr (a)
(* pi (/ a 180.0))
(defun rtd (a)
(/ (* a 180.0) pi)
(setq rad (vlax-get obj 'radius))
(setq pt2 (polar cen (+ ang 0.0) rad))
(setq pt3 (polar pt2 (+ ang (/ pi 2.0)) rad))
(setq Pt4 (polar cen (+ ang (/ pi 2.0)) rad))
(defun c:circbox ( / x ss obj ang)
(setvar "osmode" 0)
(setq ang (dtr (getreal "\nEnter Angle")))
(AH:circbox obj)
) ; repeat
) ; defun
(c:circbox)
