save as autocad drawing from excel cell
handasa
Greetings Everyone
i use this vba from excell which wrriten by mr.Christos Samaras
this vba draw blocks in the active autocad drawing
i want each time i run the vba macro save the drawing as cell A1 content
e.g. if the cell A1 is (section1) then the vba save the drawing as (section1.dwg)
any help will be appreciated
thanks in advance
Option Explicit
'A custom type that holds the scale factors of the block.
Private Type ScaleFactor
   X As Double
   Y As Double
   Z As Double
End Type
Sub InsertBlocks()
   'Inserts blocks in AutoCAD using data - insertion point, block name/full path, scale factors, rotation angle - from Excel.
   'Note that the block name or the block path must already exists, otherwise nothing will be inserted.
   'The code uses late binding, so no reference to external AutoCAD (type) library is required.
   'It goes without saying that AutoCAD must be installed at your computer before running this code.
   'Written by:    Christos Samaras
   'Date:          21/04/2014
   'e-mail:        xristos.samaras@gmail.com
   'site:          http://www.myengineeringworld.net
   'Declaring the necessary variables.
   Dim acadApp                 As Object
   Dim acadDoc                 As Object
   Dim acadBlock               As Object
   Dim LastRow                 As Long
   Dim i                       As Long
   Dim InsertionPoint(0 To 2)  As Double
   Dim BlockName               As String
   Dim BlockScale              As ScaleFactor
   Dim RotationAngle           As Double
   'Activate the coordinates sheet and find the last row.
   With Sheets("ADD SECTION")
       .Activate
       LastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
   End With
   'Check if there are coordinates for at least one circle.
   If LastRow < 2 Then
       MsgBox "There are no coordinates for the insertion point!", vbCritical, "Insertion Point Error"
       Exit Sub
   End If
   'Check if AutoCAD application is open. If is not opened create a new instance and make it visible.
   On Error Resume Next
   Set acadApp = GetObject(, "AutoCAD.Application")
   If acadApp Is Nothing Then
       Set acadApp = CreateObject("AutoCAD.Application")
       acadApp.Visible = True
   End If
   'Check (again) if there is an AutoCAD object.
       MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error"
       Exit Sub
   End If
   On Error GoTo 0
   'If there is no active drawing create a new one.
   Set acadDoc = acadApp.ActiveDocument
   If acadDoc Is Nothing Then
       Set acadDoc = acadApp.Documents.Add
   End If
   On Error GoTo 0
   'Check if the active space is paper space and change it to model space.
   If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding
       acadDoc.ActiveSpace = 1     '1 = acModelSpace in early binding
   End If
   'Loop through all the rows and add the corresponding blocks in AutoCAD.
       For i = 2 To LastRow
           'Set the block name.
           BlockName = .Range("D" & i).Value
           'If the block name is not empty, insert the block.
           If BlockName <> vbNullString Then
               'Set the insertion point.
               InsertionPoint(0) = .Range("A" & i).Value
               InsertionPoint(1) = .Range("B" & i).Value
               InsertionPoint(2) = .Range("C" & i).Value
               'Initialize the optional parameters.
               BlockScale.X = 1
               BlockScale.Y = 1
               BlockScale.Z = 1
               RotationAngle = 0
               'Set the optional parameters (if there are values on the corresponding ranges).
               If .Range("E" & i).Value <> vbNullString Then BlockScale.X = .Range("E" & i).Value
               If .Range("F" & i).Value <> vbNullString Then BlockScale.Y = .Range("F" & i).Value
               If .Range("G" & i).Value <> vbNullString Then BlockScale.Z = .Range("G" & i).Value
               If .Range("H" & i).Value <> vbNullString Then RotationAngle = .Range("H" & i).Value
               'Add the block using the sheet data (insertion point, block name, scale factors and rotation angle).
               'The 0.0174532925 is to convert degrees into radians.
               Set acadBlock = acadDoc.ModelSpace.InsertBlock(InsertionPoint, BlockName, _
                               BlockScale.X, BlockScale.Y, BlockScale.Z, RotationAngle * 0.0174532925)
           End If
       Next i
   End With
   'Zoom in to the drawing area.
   acadApp.ZoomExtents
   'Release the objects.
   Set acadBlock = Nothing
   Set acadDoc = Nothing
   Set acadApp = Nothing
   'Inform the user about the process.
   MsgBox "The blocks were successfully inserted in AutoCAD!", vbInformation, "Finished"
End Sub
Sub ClearAll()
   Dim LastRow As Long
   'Find the last row and clear all the input data..
       .Activate
       .Range("A2:H" & LastRow).ClearContents
       .Range("A2").Select
   End With
End Sub
