Results 1 to 5 of 5
    Forum Newbie
    Architectural
    arkinetico's Discipline Details
    Architect
    Architectural
    Revit Architecture 2011
    Sep 2016
    Lima, Peru
    3
    Default Filled regions and components
    Hi, when I create a filled region, for example in a bathroom or in a kitchen, all the components disappears. Then if I edit the filled region and make it transparent the patterns can be seen through the components. Somebody can show me how to fix this? and yes, i'm a rookie in Revit
    thanks
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    671
    I think it is like drawing over a viewport, so a solution is to use transparency.
    what other options do you have except using filled regions?
    but then again, I'm not deeply involved in revit..
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Forum Newbie
    Architectural
    Architect
    Architectural
    Sep 2016
    Lima, Peru
    3
    But as I said, using transparency the patterns can be seen through the components. It only works when I make a boundary in each component but takes a lot of time and is not practical. When making floor plans for presentation usually it's needed to do patterns in bathrooms and kitchens that seem like tiles.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Why not apply a tile finish to your floors? It sounds like you are expecting filled regions to behave like hatches in AutoCAD. Filled regions are not intelligent at all, they are a far cry from the functionality of hatches.
    Drafting is a breeze.
  5. #5
    Forum Newbie
    Architectural
    Architect
    Architectural
    Sep 2016
    Lima, Peru
    3
    Thanks a lot, that's the solution. You were right, I was expecting filled regions behave like hatches in Autocad
  1. My dimensions aren't filled?
    By Mike G in forum AutoCAD Beginners' Area
    Last Post: 24th Nov 2013, 02:33 pm
  2. Replies: 6
    Last Post: 22nd Feb 2011, 11:27 pm
  3. un filled polyline
    By mateen in forum AutoCAD Beginners' Area
    Last Post: 27th Nov 2010, 05:44 pm
  4. Arrows Not Filled
    By ziemerd in forum AutoCAD Beginners' Area
    Last Post: 7th Jan 2010, 05:08 pm
  5. Solidly Filled Polygon
    By rayq in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2005, 10:51 pm
