elimgo Posted September 14, 2016 Posted September 14, 2016 Hi all, I have small (but annoying) problem with getfiled. I use lisp to draw polyline from txt file in my default project folder which is located in "X:\log\" I used (getfiled "select file" "X:/log/" "npd" in the lisp routine. When the file dialog is opened, when i want to select the folder i want, it would just select the first folder in the file dialog window. So i when i double click on the folder that i want to open i always accidentaly opened the first folder. The solution is to click on the folder i want, and then it would highlight the first folder (that blue highlight on the folder), and then i click again the folder i want so it's highlighted. But it's so slow, sometimes it's annoying when i need to work fast. Is there a way so that whenever i click first on the folder i want, it would highlight it instead of the first folder? I tried the 1,4,6,16,32,64 flag but it's still the same. Help very appreciated Much thanks :) Quote
rlx Posted September 16, 2016 Posted September 16, 2016 (edited) Not sure if this will fix your 'problem' but have you checked this one out? http://www.lee-mac.com/directorydialog.html http://www.lee-mac.com/lisp/html/GetFilesV1-6.html gr. Rlx Edited September 16, 2016 by rlx Quote
elimgo Posted September 16, 2016 Author Posted September 16, 2016 Hi rlx, thank you for the reply, i will try it later Quote
elimgo Posted September 17, 2016 Author Posted September 17, 2016 Hi RLx, both are great. However what i want is as simple as this, Let's say i want to get a file name of a txt in my document. If i type like this: (getfiled "select a txt file" "randomfilename" "txt" 8 ) The file dialog will open with My Documents folder list and "randomfilename.txt" highlighted in blue in "file name" box. Then if i click the 3rd folder in my documents folder it will directly selected that folder (highlighted in blue). This is the behaviour i want. However if i do this i can not select the default folder i want (it's not in my document). But if i input the default folder that i want: (getfiled "select a txt file" "X:/Log/" "txt" 8 ) The file dialog will open X:\Log\ folder, with blinking cursor in the file name box. If i click on the third file/folder on the list, then the first file/folder will be selected (highlighted in blue). So i need to click one more time on the file i want, and then double click it if it's a folder. Problem is when i double click it i accidentally open the first folder instead of the folder i want. I want the behaviour is the same with the way it handles (getfiled "select a txt file" "randomfilename" "txt" 8 ). So whenever i click on the folder i want it will directly select that one. Is it possible? Or maybe is there a way to modify the http://www.lee-mac.com/directorydialog.html so it can select a file inside the folder too? Thanks very much Quote
elimgo Posted September 17, 2016 Author Posted September 17, 2016 hi, nevermind. i just realized i can type random file name into (getfiled "select a txt file" "X:/Log/random.txt" "txt" 8 ) problem solved :D Quote
rlx Posted September 17, 2016 Posted September 17, 2016 hi, nevermind. i just realized i can type random file name into (getfiled "select a txt file" "X:/Log/random.txt" "txt" 8 ) problem solved :D Ah , my favorite kind of problems , that solve themselves :-) Gr. Rlx Quote
elimgo Posted September 17, 2016 Author Posted September 17, 2016 the funny thing is, things are clearer when i ask it or rather when i write my problem properly Quote
