bono05 Posted September 20, 2016 Share Posted September 20, 2016 Hi, It's possible to "copy" a plot configuration to other plans (with many layout) at once? Actually i'm using a lisp this to copy a plot config to all other layout but in the same plan. Many thanks for help! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 21, 2016 Share Posted September 21, 2016 Using a script you will be suprised how quick it can carry out mods on multiple dwgs. You do not want user interaction, so your lisp to copy config to layouts would have to have any questions changed to pre-set the answer required. eg script open DWG1 (load "myplotconfigs") Close Y open DWG2 (load "myplotconfigs") Close Y Ps have a cup of coffee and all may be done by the time you finish the cup. Quote Link to comment Share on other sites More sharing options...
abra-CAD-abra Posted September 21, 2016 Share Posted September 21, 2016 This may be of use. It uses ObjectDBX to copy plot configurations from your current drawing to all drawings in a selected folder: http://forums.autodesk.com/t5/forums/forumtopicprintpage/board-id/529/message-id/93711/print-single-message/false/page/1 Quote Link to comment Share on other sites More sharing options...
bono05 Posted September 27, 2016 Author Share Posted September 27, 2016 Hi guy's! Actually i used this one to "copy" a plot config to aal others layouts...but from the same plan. It's possible to have a similair lisp but for a lot's of dwg' at once? (defun c:mpl(/ s *errmpl* MsgBox multiplie_plt) ;;;--------------------------------------------------------------- ;;; ;;; Gestion des erreurs ;;; ;;;--------------------------------------------------------------- (defun *errmpl* (msg) (if (/= msg "Function cancelled") (if (= msg "quit / exit abort") (princ) (princ (strcat "\nErreur : " msg)) ) (princ) ) (setq *error* s) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (princ) ) ;;;--------------------------------------------------------------- ;;; ;;; Message ;;; ;;;--------------------------------------------------------------- (defun MsgBox (Titre Bouttons Message / Reponse WshShell) (vl-load-com) (setq WshShell (vlax-create-object "WScript.Shell")) (setq Reponse (vlax-invoke WshShell 'Popup Message 0 Titre (itoa Bouttons))) (vlax-release-object WshShell) Reponse ) ;;;--------------------------------------------------------------- ;;; ;;; Routine principale ;;; ;;;--------------------------------------------------------------- (defun multiplie_plt(/ config doc i init_mpl j lay liste_lay lst n position positiondests resultat) (defun liste_destination() (start_list "dest") (mapcar 'add_list (vl-remove (nth (atoi position) liste_lay) liste_lay)) (end_list) (set_tile "dest" positiondest) ) (if (setq init_mpl (findfile "mpl.dcl")) (progn (setq init_mpl (load_dialog init_mpl) liste_lay nil n 1 position "0" positiondest "0" ) (vlax-for lay (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) (setq lst (cons (cons (vla-get-taborder lay) lay) lst)) ) (while (assoc n lst) (setq liste_lay (cons (vla-get-name (cdr (assoc n lst))) liste_lay)) (if (and (eq (vla-get-name (cdr (assoc n lst))) (getvar "ctab")) (zerop (getvar "tilemode"))) (setq position (itoa (1- n))) ) (setq n (1+ n)) ) (setq liste_lay (reverse liste_lay)) (if (cdr liste_lay) (progn (new_dialog "mpl" init_mpl "") (start_list "mpl") (mapcar 'add_list liste_lay) (end_list) (liste_destination) (set_tile "titre" "Copie Présentation V1.03") (set_tile "mpl" position) (mode_tile "mpl" 2) (while (and (/= resultat 1)(/= resultat 0)) (action_tile "mpl" "(setq position $value)(liste_destination)") (action_tile "dest" "(setq positiondest $value)") (action_tile "accept" "(done_dialog 1)") (action_tile "cancel" "(done_dialog 0)") (setq resultat (start_dialog)) ) (unload_dialog init_mpl) (if (eq resultat 1) (progn (setq doc (vla-get-activedocument (vlax-get-acad-object)) config (vla-item (vla-get-layouts doc) (nth (atoi position) liste_lay)) ) (setq liste_lay (vl-remove (nth (atoi position) liste_lay) liste_lay)) (while (not (eq positiondest "")) (setq position (read positiondest)) (setq lay (vla-item (vla-get-layouts doc) (nth position liste_lay))) (vla-copyfrom lay config) (princ (strcat "\nMise à jour de la mise en page de " (vla-get-name lay) " depuis " (vla-get-name config))) (setq positiondest (substr positiondest (+ 2 (strlen (itoa position))) (strlen positiondest))) ) ) ) ) (msgbox "MPL" 48 "Une seule présentation\nUtilisation inutile du Lisp") ) ) (msgbox "MPL" 16 "Fichier MPL.DCL introuvable") ) ) ;;;--------------------------------------------------------------- ;;; ;;; Routine de lancement ;;; ;;;--------------------------------------------------------------- (vl-load-com) (setq s *error*) (setq *error* *errmpl*) (vla-startundomark (vla-get-activedocument (vlax-get-acad-object))) (multiplie_plt) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (setq *error* s) (princ) ) Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted September 27, 2016 Share Posted September 27, 2016 That code is calling DCL or some sort of Dialog Box while executing... How do you plan to implement it on multiple DWGs if Box is appearing in every DWG? Maybe with avoiding Dialog Boxes and then through ObjectDBX calling DBX document VLA-OBJECT and function (lisp without Dialog Box) through DBX Wrapper : http://www.lee-mac.com/odbxbase.html Quote Link to comment Share on other sites More sharing options...
bono05 Posted September 28, 2016 Author Share Posted September 28, 2016 Hi! Maybe a good idea...but i don't understand how to make this??? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 28, 2016 Share Posted September 28, 2016 Like Marko look at these two lines (action_tile "mpl" "(setq position $value)(liste_destination)") (action_tile "dest" "(setq positiondest $value)") need to be (setq position somevalue) (setq positiondest someothervalue) remove all code above and below referring to the dialouge call. NOT TESTED (new_dialog "mpl" init_mpl "") ............ (setq position somevalue) (setq positiondest someothervalue) ...................... (unload_dialog init_mpl) Quote Link to comment Share on other sites More sharing options...
