Hello, I'm new here.
I have little knowledge about visual lisp and I wanted to ask about methods:
; Methods supported:
; AddVertex (2)
; ArrayPolar (3)
; ArrayRectangular (6)
; Copy ()
; Delete ()
; Explode ()
; GetBoundingBox (2)
; GetBulge (1)
; GetExtensionDictionary ()
; GetWidth (3)
; GetXData (3)
; Highlight (1)
; IntersectWith (2)
; Mirror (2)
; Mirror3D (3)
; Move (2)
; Offset (1)
; Rotate (2)
; Rotate3D (3)
; ScaleEntity (2)
; SetBulge (2)
; SetWidth (3)
; SetXData (2)
; TransformBy (1)
; Update ()
What these numbers behind each 'method' mean ? And how to use them?
I tried (vla-put-Offset o (getdist)) but it doesn't work.
Numbers represent number of arguments required for each method (without main VLA-OBJECT argument) to work...
For ex.
(vla-copy VLA-OBJECT)
(vla-addvertex VLA-OBJECT parameterofsegment (vlax-3d-point pt))
(vla-setbulge VLA-OBJECT parameterofsegment bulgevalue)
And yes : vla-offset :
(vla-offset VLA-OBJECT value(positve or negative real number) - "not (getdist)")
Okay, now I understand. But how do you know what type of arguments are required for every method?
does vla-Move require vla-object and 2 points or 1 point and real number ?
vla-move requires 2 points (base point) and (destination point), of course as variants :
(vla-move VLA-OBJECT (vlax-3d-point p1) (vlax-3d-point p2))
You have to experiment - I also don't have reference for this, but some things are logical - like command MOVE (so it's the same as with (vla-move))
This is a very good website mr.Tharwat, thank you for sharing it.
mr.Ribar thank you for helping me out, now I will learn how to deal with these methods.
You are welcome - happy coding.
(car (entsel)) just watch out for the vla-add's they require which space its to be added within, but basicly the same as command line.
An example from Afralisp
[b];Get the ModelSpace collection of the active document,;select center point and radius: [/b]
[b](setq thisdrawing (vla-get-activedocument (vlax-get-acad-object)))[/b]
[b](setq mspace (vla-get-modelspace thisdrawing))[/b]
[b](setq pt1 (vlax-3d-point (getpoint "\nCenter point: ")))[/b]
[b](setq rad (getreal "\nRadius: "))[/b]
[b][color=#ff0000](vla-AddCircle mspace pt1 rad)[/color] [/b]
Thank you for mentioning this mr.BIGAL,
But that brings up another question of mine: Is there a way to automatically determine the active space, so the vla-Add method won't cause any problems?
(vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
This should return mspace VLA-OBJECT if mspace is active...
Another example I believe from Lee-mac.
; I believe from Lee-mac.
(setq doc (vla-get-ActiveDocument
             (vlax-get-Acad-Object))
       spc (if
             (zerop
               (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc)))
Heres what I use:
(setq
acDoc (vla-get-ActiveDocument (vlax-get-acad-object))
AcSpc (vlax-get acDoc (if (= acModelSpace (vla-get-ActiveSpace acDoc)) 'ModelSpace (if (= (vla-get-mSpace acDoc) :vlax-true) 'ModelSpace 'PaperSpace)))
Edited by Grrr
Heres what I use:
(= acModelSpace acDoc)
This will never return T: acmodelspace is an enumeration for the activespace property, and you have assigned the activedocument vla-object to the symbol acDoc.
Woops, corrected the above code. Thanks!
