How to input spherical and cylindrical coordinates with autolisp?
I want to write a routine that converts a text file of Cartesian coordinates to either spherical or cylindrical coordinates. What is the method and format, for example for the command function to draw a line in autolisp with spherical and cylindrical coordinates.
I know how to input manually these coordinates but I don't know how to do it automatically with AutoLISP.
Any help will be appreciated.
Thanks,
Andrew
The general syntax for spherical coordinates is
length
or for relative coordinates
@ length
The general syntax for cylindrical coordinates is
length
or for relative cylindrical coordinates
@length
You can use this in Lisp - see the example
(setq l1 1000)
(setq w1 90)
(setq w2 -90)
(setq pt (strcat "@" (rtos l1) "
@1000.0000
Hope this helps
Regards
Jochen
http://www.ant-ares.de
Hello scj,
You gave me the method that I needed. Sometimes spherical and cylindrical allows me to create objects easier.
Thank you,
Andrew
Hello Lee Mac,
I am using a spherical and cylindrical routine to input 3-D objects into AutoCAD. I only wanted to alter my routine to to the syntax for spherical and cylindrical input in AutoLISP. I can't see why the study of the polar function would help. scj understood what I was trying to convey.
Many people are experts on this site and you are one of them, however scj gave me what I wanted. Interpreting someone's email can be hit or miss.
Your assistance is always welcome.
Thanks,
Andrew
I agree with Lee and Marco looking into polar function will answers questions further down the track.
basic angle functions
o/h = sin(ang)
a/h = cos(ang)
o/a = tan(ang)
others have a habit of answering
(defun dtr (a)
(* pi (/ a 180.0))
(defun tan (a)
 (setq a (dtr a))
 (/ (sin a)(cos a))
(setq orgpt (list 0 0 0)) ; set your base pt
(setq pt (polar orgpt (dtr w1) L1))
(setq z (* l1 (tan (dtr w2))))
(setq pt (list (car pt)(cadr pt)(+ z (caddr pt)))
Edited by BIGAL
A bit of fun
(defun dtr (a)
(* pi (/ a 180.0))
(defun tan (a)
 (setq a (dtr a))
 (/ (sin a)(cos a))
(setq cenpt (list 0 0 0))
(setq ang1 0.0)
(setq ang2 0.0)
(setq rad 1000.0)
(repeat 59
(repeat 59
(setq pt (polar cenpt ang1 rad))
(setq pt (list (car pt)(cadr pt)(+ (* rad (tan (dtr ang2)))) ))
(command "point" pt)
(setq ang1 (+ ang1 6.0))
(setq ang2 (+ ang2 6.0))
(command "-vpoint" "1,1,1")
Edited by BIGAL
The existing suggestion is restricted to basic command-line input, however, if you were to generate objects using any other means (such as ActiveX or entmake, for example), the points would need to be expressed as a cartesian point list. As such, the AutoLISP polar function will allow you to calculate a point at a given angle & radius from a base point.
FYI, polar function is derived from (sin ang) and (cos ang) functions... So actually no need for polar as must...
Of course there are other methods, but the equivalent of:
(polar pnt ang dis)
Using sin/cos would be:
(mapcar '+ pnt (list (* dis (cos ang)) (* dis (sin ang))))
Which is unnecessary.
