gmmdinesh Posted September 28, 2016 Share Posted September 28, 2016 (edited) Hi, I need a lisp code for rotate and explode when insertion of block. Thanks in advance, Edited April 7, 2022 by gmmdinesh Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 28, 2016 Share Posted September 28, 2016 Is the user going to be prompted for the name of the block or is it going to be specified as part of the lisp routine? Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 28, 2016 Share Posted September 28, 2016 These are all options that can be accomplished from the INSERT dialog. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 28, 2016 Share Posted September 28, 2016 You could even use Tool Palettes to remove some of the steps if the target block is inserted on a regular basis. Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 28, 2016 Share Posted September 28, 2016 You could even use Tool Palettes to remove some of the steps if the target block is inserted on a regular basis. Even better. I feel like tool palettes is such an underused feature. Quote Link to comment Share on other sites More sharing options...
jonathann3891 Posted September 29, 2016 Share Posted September 29, 2016 But if you wanted to do it with a lisp you can start with something like this (defun c:test () (command "insert" "span" pause "" "" pause "_.explode" "_L") ) Span is the block name. Make sure to have a support path pointed to where you keep your blocks. Quote Link to comment Share on other sites More sharing options...
