JoeyG_77 Posted September 28, 2016 Posted September 28, 2016 Hey everyone !! ... I have a questions... is there a lisp function that will match dynamic properties if the block is named the same. Example: If i have a distance set in one block and want 3 other blocks to match that distance is there a function that will do this. Thanks for the help Joey G Quote
Lee Mac Posted September 28, 2016 Posted September 28, 2016 https://www.theswamp.org/index.php?topic=44444.msg496892#msg496892 Quote
Grrr Posted September 28, 2016 Posted September 28, 2016 How did I missed this! I thought about writing myself one, but It already existed... (maybe I'm a bad googler). Nice one, Lee! Quote
JoeyG_77 Posted September 29, 2016 Author Posted September 29, 2016 OMG !! ... LEE MAC !! you are amazing !! Thank you , Worked perfect Quote
Jochem Beullens Posted March 29, 2024 Posted March 29, 2024 (edited) Hello all, How can I adjust the lisp routine of Lee Mac so that only the custom property Angle1 is matched and that it is possible to match this properties between blocks with different names? ;; Match Dynamic Block Properties - Lee Mac ;; Matches all dynamic block properties from a selected source dynamic block ;; to all selected destination dynamic blocks of the same name. (defun c:dynmatch ( / blk des inc obj prp src ) (while (progn (setvar 'errno 0) (setq src (car (entsel "\nSelect Source Dynamic Block: "))) (cond ( (= 7 (getvar 'errno)) (princ "\nMissed, try again.") ) ( (= 'ename (type src)) (cond ( (/= "INSERT" (cdr (assoc 0 (entget src)))) (princ "\nObject is not a block.") ) ( (= :vlax-false (vla-get-isdynamicblock (setq src (vlax-ename->vla-object src)))) (princ "\nBlock is not dynamic.") ) ) ) ) ) ) (if (and (= 'vla-object (type src)) (setq des (LM:ssget "\nSelect Destination Dynamic Blocks: " (list "_:L" (list '(0 . "INSERT") (cons 2 (strcat "`*U*," (setq blk (strcase (vla-get-effectivename src))) ) ) ) ) ) ) (setq prp (mapcar 'vla-get-value (vlax-invoke src 'getdynamicblockproperties) ) ) ) (repeat (setq inc (sslength des)) (setq obj (vlax-ename->vla-object (ssname des (setq inc (1- inc))))) (if (= (strcase (vla-get-effectivename obj)) blk) (mapcar (function (lambda ( a b ) (if (/= "ORIGIN" (strcase (vla-get-propertyname a))) (vla-put-value a b) ) ) ) (vlax-invoke obj 'getdynamicblockproperties) prp ) ) ) ) (princ) ) ;; ssget - Lee Mac ;; A wrapper for the ssget function to permit the use of a custom selection prompt ;; ;; Arguments: ;; msg - selection prompt ;; params - list of ssget arguments (defun LM:ssget ( msg params / sel ) (princ msg) (setvar 'nomutt 1) (setq sel (vl-catch-all-apply 'ssget params)) (setvar 'nomutt 0) (if (not (vl-catch-all-error-p sel)) sel) ) (vl-load-com) (princ) Edited March 31, 2024 by CADTutor Added code block Quote
Lee Mac Posted March 31, 2024 Posted March 31, 2024 Try the following untested code - change the pattern parameter to suit which parameters should be matched: ;; Match Dynamic Block Properties - Lee Mac ;; Matches all dynamic block properties from a selected source dynamic block ;; to all selected destination dynamic blocks holding matching parameters (defun c:dynmatch ( / blk des inc obj pat prp src val ) (setq pat "Angle1") ;; Change to "*" to match all (while (progn (setvar 'errno 0) (setq src (car (entsel "\nSelect Source Dynamic Block: "))) (cond ( (= 7 (getvar 'errno)) (princ "\nMissed, try again.") ) ( (= 'ename (type src)) (cond ( (/= "INSERT" (cdr (assoc 0 (entget src)))) (princ "\nObject is not a block.") ) ( (= :vlax-false (vla-get-isdynamicblock (setq src (vlax-ename->vla-object src)))) (princ "\nBlock is not dynamic.") ) ( (not (setq prp (vl-remove-if '(lambda ( p ) (or (= "ORIGIN" (car p)) (not (wcmatch (car p) (strcase pat))))) (mapcar '(lambda ( x ) (cons (strcase (vla-get-propertyname x)) (vlax-get x 'value))) (vlax-invoke src 'getdynamicblockproperties) ) ) ) ) (princ "\nBlock has no dynamic parameters to match.") ) ) ) ) ) ) (if (and (= 'vla-object (type src)) (setq des (LM:ssget "\nSelect Destination Dynamic Blocks: " '("_:L" ((0 . "INSERT"))))) ) (repeat (setq inc (sslength des)) (setq inc (1- inc) obj (vlax-ename->vla-object (ssname des inc)) ) (if (= :vlax-true (vla-get-isdynamicblock obj)) (foreach p (vlax-invoke obj 'getdynamicblockproperties) (if (setq val (cdr (assoc (strcase (vla-get-propertyname a)) prp))) (vla-put-value p val) ) ) ) ) ) (princ) ) ;; ssget - Lee Mac ;; A wrapper for the ssget function to permit the use of a custom selection prompt ;; ;; Arguments: ;; msg - selection prompt ;; params - list of ssget arguments (defun LM:ssget ( msg params / sel ) (princ msg) (setvar 'nomutt 1) (setq sel (vl-catch-all-apply 'ssget params)) (setvar 'nomutt 0) (if (not (vl-catch-all-error-p sel)) sel) ) (vl-load-com) (princ) Quote
