alijahed Posted October 10, 2016 Share Posted October 10, 2016 Hi All, Simple but confusing! I am in drawing area. I go to Manage>styles editor hitting to layer structure then setup layers there. All good... Then you go to your title block or any sketch environment, select a line, under Sketch tab > Format you don't have Layer Name option to assign your selected object to a specific layer. You can almost change everything but the Layer, not only that it doesn't give you information the layer that selected object has been drawn! (see attached) Basically, I want to assign a layer to a selected object in my sketch. Please help Cheers Ali Quote Link to comment Share on other sites More sharing options...
kpyoung333 Posted October 12, 2016 Share Posted October 12, 2016 Instead of going to the Sketch tab, go to the Annotate tab and you will have the layer selection under the Format area. You can select existing visible lines and change them to hidden/border/custom from here. If you create a sketch on a view that is when that Sketch>Format area becomes useful. Quote Link to comment Share on other sites More sharing options...
alijahed Posted October 13, 2016 Author Share Posted October 13, 2016 Thanks Mate! Quote Link to comment Share on other sites More sharing options...
