Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Full Member
    AutoCAD 2015
    Feb 2016
    40
    Default Quick question re: block insertion
    I'm going to sound dumb here, but I can't figure this one out using the normal Googly avenues. Sorry if I'm missing a thread and this is a duplicate.
    Say I have some geometry that I want a 2D block of. So, I orient the camera, and use the FLATSHOT command.
    The resulting block always has an insertion point of... how do I explain this? It's the same distance from the crosshairs as the origin was when the block was created. It's not AT the origin, it's at a certain distance away from the crosshair. So, if my geometry is far enough away from the origin, I have to zoom way out after creating the block just to be able to see where it is and be able to locate it with a final left click.
    I don't get why this would ever be the case. In my mind, either a block is always inserted at the origin (or another specified point), or it's inserted at the crosshair. I don't understand how what's happening now would ever be useful.
    Anyway, am I just missing some obvious system variable, or something?
    Thanks in advance.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Dadgad: I think the OP is specifically referring to blocks created by the FLATSHOT command.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Perhaps you could explode the block and redefine it with the insertion point more to your liking.
    The block is referenced to the UCS of the camera view plane that you used.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    or skip explode and use the block editor.
    Drafting is a breeze.
  5. #5
    Full Member
    AutoCAD 2015
    Feb 2016
    40
    Hey guys, thanks for the replies. In this instance I guess it's fine to just consider blocks created through the FLATSHOT command.
    Exploding a block, or using a block editor, would not work, because in my example the block hasn't been placed yet.
    The steps are as such:
    1. Isolate and orient your stuff.
    2. FLATSHOT, enter.
    3. A block appears in a weird location at some seemingly arbitrary distance from the crosshair. This is the issue. It doesn't appear AT the crosshair, it's somewhere else relative to it. (As a corollary, I'd really like to know why this would ever happen).
    4. So, you have to zoom way out to see where it actually is to be able to locate it where you want.
    5. Once you finally figure that out, you left-click to place it, then scale and rotate it as with a normal block insertion.
    6. Only now can you EXPLODE or BEDIT... way after the problem has occurred.
    I hope that's clear enough. It seems the insertion point of the block wants to be nowhere near where the geometry? It's tremendously obnoxious if you want the block you create through FLATSHOT to be close to the geometry in model space.
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Editing the block was suggested because the block is not created the way you like it. It's an easy fix (workaround), if you cannot figure out how to create it as you desire it to be.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I think eldon kind of hinted at what the cause may be when he wrote..."The block is referenced to the UCS of the camera view plane that you used."
  8. #8
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Relocate the UCS so that it is on the object, then use Flatshot.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    It might save effort if you export the flatshot to an external file in the first place. You know it is the only object in that drawing. Then it is easy to fix the insertion point to your preference.
  10. #10
    Full Member
    AutoCAD 2015
    Feb 2016
    40
    Ugh... duh. Thanks rkent and ReMark, again, as well as eldon and RobDraw. I should have been able to figure this out myself. I'm pretty weak on UCS manipulation, and what I was toying around with before wasn't really working. I was orienting the camera with the buttons on the view toolbar, which would reset the UCS to that view (which is annoying), so I would UCS -> W to give myself a normal coordinate system before I created the block. Clearly that is my "issue." I'm still not sure why anyone would want that, but that's neither here nor there.
    Thanks again, guys!
  1. Block insertion routine based on part block file name
    By legg1979 in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2013, 06:02 pm
  2. Quick question.
    By pqphillips in forum Electrical
    Last Post: 19th Jun 2013, 04:04 pm
  3. Quick question !
    By CadFrank in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Oct 2012, 02:04 pm
  4. New Thread Suggestion: Quick Question, Quick Answer
    By Pintoleite in forum Feedback
    Last Post: 11th Apr 2012, 01:23 pm
  5. Blocks and insertion units question
    By soleary in forum AutoCAD Drawing Management & Output
    Last Post: 9th Dec 2008, 09:18 pm
