Princ to Screen
cadsterdyne
Hi Cadtutors
Could anybody please let me know how to invoke text command so that what ever result i am "princ"ing to command line.
i want to be able to paste it on screen through text command, pick a point where the "princ" result is ready to be placed in model space.
;|  ARSQ, Area and Perimeter of Rectangle when Length and Width are known
Variables
len     Length of Rectangle
wid   	Width of Rectangle     |;
(defun c:arsq()
(setq len ( getreal "\nEnter Length Of Rectangle \n"))
(setq wid ( getreal "\nEnter Widh Of Rectangle \n"))
(setq peri (* len wid))
(princ (strcat "\nThe Area Of Rectangle is = " (rtos peri 2 4 ) " Sqm"))
(setq are (* 2 (+ len wid)))
(princ (strcat "\nThe Perimeter Of Rectangle is = " (rtos are 2 4 ) " Sqm"))
Thanks in Advance.
Cadsterdyne
This?
(defun c:arsq (/ len wid pnt are per)
 (and (setq len (getreal "\nEnter Length Of Rectangle :"))
      (setq wid (getreal "\nEnter Widh Of Rectangle :"))
      (setq are (strcat "The Area Of Rectangle is = " (rtos (* len wid) 2 4) " Sqm"))
      (setq per (strcat "The Perimeter Of Rectangle is = " (rtos (* 2 (+ len wid)) 2 4) " Sqm"))
      (princ (strcat "\n" are))
      (princ (strcat "\n" per))
      (setq pnt (getpoint "\nSpecify text location :"))
      (entmake (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText")
          (cons 10 (trans pnt 1 0))
          (cons 40 (* (getvar "DIMSCALE") 2.0))
          (cons 7 (getvar 'TEXTSTYLE))
          (cons 1 (strcat are "\\P" per))
Exactly what i meant Tharwat!
Thank you so much.
I can see the changes you added to the code. as i am a beginner at learning AutoLISP, could you please direct me to some place where i can lookup details about invoking commands?
as i see you didnt use
command ".text"
to accomplish the above requirement. i dont even know if that exist's. or is the right way to go, i want to learn more about code formats for various commands. i hope i am conveying what iam trying to learn.
Thanks again.
You are welcome :)
Actually I used the entmake function instead of command call which is better in all cases and specially when you have many object to be created which the factor of speed would force its self in this ring.:D besides that programming is not a use of command unless you have no better go with your aim of a program.
Hit THIS for more information about entmake function.
Edited by Tharwat
words missing added
You are welcome :)
Actually I used the entmake function instead of command call which is better in all cases and specially when you have many object to be created which the factor of speed would force its self in this ring.:D besides that programming is not a use of command unless you have no better go your aim of a program.
very nice Thaerwat!
cadsterdyne when using command there are switches you can use . - _ I am trying to find the details if I remember right the . is language so a German Autocad would see command as just that. Just at command line type LA and see what happens then do -LA An example if using command in lisp often need say -hatch so no dialouge will open and an area is hatched.
Just at command line type LA and see what happens then do -LA .
Thanks BIGAL i see how that can add to a speedy workflow. Thanks for sharing. :thumbsup:
On the lines of Speed in Code found this interesting.
(entmake) vs (command) vs (vla-add-) Speed Test!!
http://cadpanacea.com/wp/?p=1542
