Scale method (alternative for block inside block method)
Hi all
For scaling purposes i tweaked a routine to let me scale a selectionset in Z direction.
Works good, but the disadvantage is that it will not work in 'Refedit mode'.
Since in 3D i a lot of work is within blocks i really am looking for a other methode than this -insert / purge method. Idea to do this with some kind of vla call?
(defun C:SXYZ (/ SS IP XS YS ZS RA)
 (setvar "cmdecho" 0)
 (setq SS (ssget)
IP (getpoint "Enter Base point (temp. blockname 'xstemp' will be used :")
 ) ;_ end of setq
 (initget 6)
 (setq XS (getreal "Enter X scale factor <1>:"))
 (initget 6)
 (setq YS (getreal "Enter Y scale factor (default=X):"))
 (setq ZS (getreal "Enter Z scale factor (default=X):")
RA (getreal "Enter Rotation angle <0>:")
 ) ;_ end of setq
 (if (= XS NIL)
   (setq XS 1)
 ) ;_ end of if
 (if (= YS NIL)
   (setq YS XS)
 ) ;_ end of if
 (if (= ZS NIL)
   (setq ZS XS)
 ) ;_ end of if
 (if (= RA NIL)
   (setq RA 0)
 ) ;_ end of if
 (command
   "block"  "xstemp" IP       SS ""  "insert" "xstemp"
   IP      "xyz"    XS       YS ZS  RA   "explode"
   "l"      "purge"  "b"      "xstemp" "n"
  ) ;_ end of command
Hi all
(vl-load-com)
(defun c:test()
 (if
   (setq p2 (getpoint "\nSpecify the insertion point:\n "))
      (setq _blkName "PONTO"
     _scaleX 1.0
     _scaleY 1.0
     _scaleZ 1.0
     _rotation 0
      ) ;_ >setq
      (setq vla-obj	(vla-insertblock
	   (if (eq (getvar "cvport") 1)
	     vla-get-paperspace
	     vla-get-modelspace
	   ) ;_ >if
	    (vla-get-ActiveDocument
	      (vlax-get-acad-object)
	    ) ;_ >vla-get-ActiveDocument
	  (vlax-3d-point p2)
	  _blkName
	  _scaleX
	  _scaleY
	  _scaleZ
	  _rotation
	) ;_ >vla-insertblock
      ) ;_ >setq
      (redraw (entlast) 1)
      vla-obj
    ) ;_ >progn
 ) ;_ >if
) ;_ >defun
I hope this code will help you.
Best regards
Luís Augusto
Thanks Luis! I will give it a try.. code sure looks pretty
EDIT:
:test no result in AutoCAD
; error: Automation Error. Filer error
I think the part
(vlax-3d-point p2)
What also doesn't work is this..
 (vla-insertblock
      vla-get-paperspace
      vla-get-modelspace
    ) ;_ >if
   (vlax-3d-point IP)
   xstemp                                            ; is this correct? how to call a name by block?
   XS
   YS
   ZS
   RA
Edited by halam
Another suggestion use a cond for multiple if's
(cond
   ((= XS NIL)(setq XS 1))
   ((= YS NIL)(setq YS XS))
   ((= ZS NIL)(setq ZS XS))
   ((= RA NIL)(setq RA 0))
That was the reference I used.
I hope it helps you.
http://www.afralisp.net/archive/methods/lista/insertblock_method.htm
(defun c:test ()
 ;---------------{sub function}---------------;
 (defun insBlock (
	   _blkName		;string
	   _scaleX		;real
	   _scaleY		;real
	   _scaleZ		;real
	   _rotation		;real
	   _blkInsertPoint
	   *error*
   (defun *error* (errmsg)
     (princ "\nAn error has occurred in the programme.\n ")
     (prompt errmsg)
   ) ;_ >defun
   (setq thisdrawing
   (vla-get-activedocument
   ) ;_ >vla-get-activedocument
   ) ;_ >setq
   (setq mspace (vla-get-modelspace thisdrawing))
   (setq util (vla-get-utility thisdrawing))
   (if	(not (tblsearch "BLOCK" _blkName))
     (if
(and
  (setq filePath (findfile (strcat _blkName ".dwg")))
  (progn (command "_.-insert" filePath nil) t)
) ;_ >and
 (setq blkFlag t)
 (setq blkFlag nil)
     ) ;_ >if
     (setq blkFlag t)
   ) ;_ >if
   (if	blkFlag
(setq _blkInsertPoint (vla-GetPoint util nil "\nInsertion Point: "))
(setq vla-obj
       (vla-insertblock
	 mspace
	 _blkInsertPoint
	 _blkName
	 _scaleX
	 _scaleY
	 _scaleZ
	 _rotation
) ;_ >setq
vla-obj
     ) ;_ >progn
     (alert "Block not found.")
   ) ;_ >if
 ) ;_ >defun
 (setq	vla-obj		;get-vlaObject
 (insBlock	;call sub function
   "blkName"	;your block name
   1.0		;scale x
   1.0		;scale y
   1.0		;scale z
   0.0		;rotation
 ) ;_ >insBlock
 ) ;_ >setq
) ;_ >defun
Edited by Luís Augusto
Heres another example:
(defun C:test ( / acDoc AcSpc MyBlockName XS YS ZS Rot insPt BlkRefObj )
(setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq	AcSpc
	(vlax-get
		acDoc
		(if (= acModelSpace (vla-get-ActiveSpace acDoc))
			'ModelSpace
			(if (= (vla-get-mSpace acDoc) :vlax-true)
				'ModelSpace
				'PaperSpace
)'; setq
(setq
	MyBlockName "MyBlock"
	XS 1.0
	YS 1.0
	ZS 1.0
	Rot 0.0 ; Value in degrees
); setq
(if
	(and
		(not (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list (vla-get-Blocks acDoc) MyBlockName))))
		(setq insPt (getpoint (strcat "\nSpecify \"" MyBlockName "\" insertion point: ")))
	(setq BlkRefObj (vla-InsertBlock AcSpc (vlax-3D-point insPt) MyBlockName XS YS ZS (* pi (/ Rot 180))))
);| defun |; (or (vlax-get-acad-object) (vl-load-com)) (princ)
AFAIK the problem of the original code is the use of the _BLOCK command and not the _INSERT command. Creating alternative insert code, although interesting, will not solve the OP's problem.
Thanks for your replies guys
Luis' is very nice but works only in 'normal' mode, not inside the block editor.
Command: #
Command: ** Self reference detected:
1 block reference not added to the work set.
I think ..
- there is no other way to 'deform' XYZ other than manipulate 'as block'
- one way as workaround for it..
1. 'refset' => remove selected =>
2. 'refclose'
3. SXYZ selected
4. 'refedit' previous block you where working in..
5. 'refset' => add the selected (scaled) . done.
This is just what would be done manually... faster if automated
Some good 'refset' add / remove & Refedit function... searching _.-REFEDIT
Have you tried to use the entmod function?
I think maybe my little knowledge will not be enough to help you.
Is it possible you post a sample drawing so we can try?
Hans,
Its not possible to add block reference inside that same block's definition, thats why you have this error.
Usually when I attempt such thing my ACAD crashes (for example try LM's program, called "AddObjects2Block" and pick for a source and destination objects two block references of the same block name).
Simply said its like trying to nest "BlockA" inside of "BlockA".
Another example is if you have 2 blocks and "BlockB" is nested inside "BlockA", then you can not nest "BlockA" inside "BlockB".
I will look at the a entmod method later, thanks for that Luis. ALso for the suggested routine that Lee Mac has made.
@Grrr. I don't think you clearly see the problem i have while working in blockedit mode.
The routine only temporary uses a block. It gets purged after the scaling has taken place.
My problem is that the (default) commands (methods i can think of) for creating blocks are blocked in the first place. Beacuse of the fact that you cannot define or a block while working in a block. I think there is a reason for that but i'm not that deep into de logic behind dwg hyrarchy. Why is that?
.. Still, i would be very happy of have a way to scale XY(Z) WHILE i am defining 3D blocks that have multiple parts and inserted in many places...
Kind regards hans
