+ Reply to Thread
Results 1 to 2 of 2
Thread: Using Field
  1. #1
    Forum Newbie
    Using
    Mechanical 2017
    Join Date
    Oct 2016
    Posts
    1
    Default Using Field
    Hello,
    I am trying to figure out a way to get all of my common data (detail numbers, sheet numbers, and when I bubble an item from my BOM) to update easier. The best way I found to do this seems to be using Field. Field works with regular text really well, but I cant figure out how to get the correct data from Mtext or from a table. Meaning, Field pulls all data from Mtext, and only table data from tables (i.e, nothing inserted inside the table, just table height and whatnot).
    I would like to use a table so that I can copy paste my BOM from excel, and Field reference to the data in that table.
    If you have an easier solution I would appreciate that too.. Using full Autocad 2017, Mechanical.
    Also, I tried using Custom Drawing Properties but that maxes out at 10, and I cannot populate it easily from the excel file.
    I know I can use sheetset for the sheet numbers, but see no way to use it for the BOM.
  2. #2
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO 64-bit
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    Pentium(R) i5 4570 @ 3.2GHz
    RAM:
    8 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    12,128
    Default
    I populate Excel information into an AutoCAD Table using a Data Link.
    If you could post an example of what you are using a Field to do it might be easier to solve. (Post a drawing with clear instructions.)
Similar Threads
  1. field
    By issammesk in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Jun 2016, 02:10 pm
  2. AutoLISP - move value from object data field to elevation field
    By cfculligan in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2014, 08:12 am
  3. Updating field-to-field-to-field
    By Marco1979 in forum AutoCAD General
    Last Post: 24th Apr 2014, 09:49 am
  4. Field Edit or Field Input Automation
    By KAPC in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Jun 2013, 01:04 pm
  5. ATTEXT:invalid field specification, invalid field specification, etc etc
    By Edward Teller in forum AutoCAD Beginners' Area
    Last Post: 27th Mar 2012, 05:18 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
