Hi friends
Can you pls provide me a lips for following
1) rename my Drawing no from 001-5020
to MUP-001-5050
2) rename my drawing no MUP-001-5050 To 001-5050
in first lips just add MUP-
In second just replace MUP-
Thanks
Did you mean rename the title or rename the file ?
Thanks mostafa
i mean the rename the text within in the drawing only..
rename the text with MUP-
Thanks mostafa
What about find and replace?
i wish to done this by lips, bz i have to repeat this every drawing
Thank you
there is any lips , when i click on the text and it will automatically rename in to by adding "mup"+ current text
(defun c:SwitchTxt ( / enm obj str)
 (if
   (and
     (setq enm (car (nentsel)))
     (setq obj (vlax-ename->vla-object enm))
     (vlax-property-available-p obj 'textstring)
   (vla-put-textstring
     obj
     (if (wcmatch (strcase (setq str (vla-get-textstring obj))) "MUP-*")
       (substr str 5)
       (strcat "MUP-" str)
Thank you
Ok try this.
(defun C:addmup ( / END ENT I SSET TXT)
 (setq sset (ssget '((0 . "*TEXT"))))
 (setq i (sslength sset))
 (while (not (minusp (setq i (1- i))))
   (setq ent (ssname sset i)
     end (entget ent)
     txt (cdr (assoc 1 end))
     end (subst(cons 1(if (strcat txt )(strcat "MUP-" txt)))
          (assoc 1 end) end))
   (entmod end)
Excellent :D:D:D it works
how you learn this lips , i am using many lips, but all of them got contributed good people like you :)
when i will learn to make some lips :P
Ok try this.
     end (entget ent)
          (assoc 1 end) end))
   (entmod end)
Excellent
:D
:D:D it works
:P
Thank you roy :D , its working fine with me now, thank for your good heart
Copy "001-500" to clipboard using Ctrl+C , FIND Ctrl+V in Replace MUP then Ctrl V replace ALL no need for code. Its an alternative method.
