halam Posted October 25, 2016 Share Posted October 25, 2016 Hi guys, Quick question for smart people.. I noticed AutoCAD 2017 has a new feature in the blockediting function i use. Now it defaults on 'multiple mode'. Is this a setvar one can 'force' in lisp to set to 'single'? I use a oevrall lisp thats let you edit everything, at least text mtext, attdef and dims. 2016: Command: TEXTEDIT Select an annotation object: 2017: Command: TEXTEDIT Current settings: Edit mode = Single Select an annotation object or [Mode]: m Enter a text edit mode option [single/Multiple] : (default is multiple) once set to single my lisp works again. (defun c:ed (/ SS CNT NUM SENT ANS oldsnp ent els tx1 sta ) ; (TEXTSCR) (graphscr) (command "undo" "group") (setq oldsnp (getvar "snapmode")) (setvar "snapmode" 0) (prompt "\n Multi-Edit ") (if (>= (getvar "acadver") "13") (setq SS (ssget '((-4 . "<or") (0 . "RTEXT") (0 . "ATTDEF") (0 . "DIMENSION") (0 . "MTEXT") (0 . "TEXT") (0 . "MULTILEADER") (0 . "TOLERANCE") (-4 . "<and") (0 . "INSERT") (66 . 1) (-4 . "and>") (-4 . "or>") ) ) ) (setq SS (ssget '((-4 . "<or") (0 . "ATTDEF") (0 . "TEXT") (-4 . "<and") (0 . "INSERT") (66 . 1) (-4 . "and>") (-4 . "or>") ) ) ) ) (if SS (progn (setq NUM (sslength SS) CNT 0 ) (while (< CNT NUM) (princ (strcat "\r Edit : " (rtos (1+ CNT) 2 0) " of " (rtos NUM 2 0) ": " ) ) (setq SENT (ssname SS CNT)) (setq ANS (cdr (assoc 0 (entget SENT)))) (cond ((or (eq ANS "ATTDEF") (eq ANS "TEXT") (eq ANS "TOLERANCE") (eq ANS "MULTILEADER") ) (command "textedit" SENT \) ) ((or (eq ANS "MTEXT") ) (command "mtedit" SENT \) ) ((or (eq ANS "rtext") ) (command "rtedit" SENT \ pause) ) ((or (eq ANS "DIMENSION") ) (command "textedit" SENT \) ;**** HERE IT SHOULD BE IN SINGLE VAR *** ) ;;;;;;;;;; fundtion for dte - not available ((eq ANS "INSERT") ; (command "DDatte" SENT \) (sssetfirst nil (ssadd sent)) (command "ddatte") ; ddatte2 doet het even niet... ) ((eq ANS "RTEXT") (c:RTEDIT)) ) (entupd SENT) (setq CNT (1+ CNT)) ) (princ " Done... ") ) (princ " Nothing selected. ") ) (setvar "snapmode" oldsnp) (command "undo" "end") (princ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 26, 2016 Share Posted October 26, 2016 You can return the is it 13 14 15 16 17 etc so could patch your program to check, bit like TEXT ht set or is it zero, has two answers. (setq vrsn (vlax-product-key)) (cond ((vl-string-search "R17.2" vrsn) (setq appstr "6.0")) ;09 ((vl-string-search "R18.0" vrsn) (setq appstr "7.0")) ;10 ((vl-string-search "R18.1" vrsn) (setq appstr "8.0")) ;11 ((vl-string-search "R18.2" vrsn) (setq appstr "9.0")) ;12 ? ((vl-string-search "R19.0" vrsn) (setq appstr "10.0")) ;13 ((vl-string-search "R19.1" vrsn)(setq appstr "10.3"));;2014 ((vl-string-search "R20.0" vrsn)(setq appstr "10.4"));;2015 ((vl-string-search "R20.1" vrsn)(setq appstr "10.5"));;2016 ((vl-string-search "R21.0" vrsn)(setq appstr "11.0"));;2017 ((alert "This version of C3D not supported!")) Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted October 26, 2016 Share Posted October 26, 2016 TEXTEDITMODE Quote Link to comment Share on other sites More sharing options...
halam Posted October 26, 2016 Author Share Posted October 26, 2016 Thanks Roy.. That seems logical.. Quote Link to comment Share on other sites More sharing options...
