Results 1 to 7 of 7
    Forum Newbie
    Manufacture
    bushlake's Discipline Details
    Electrical Engineer
    Manufacture
    AutoCAD 2015
    Oct 2016
    Sweden
    2
    Default Changing line space factor for multiple Mtext
    Hello.
    I want to change line space factor for all the mtext objects in a hole bunch of drawings by script.
    I found this lisp and it works fine but only by manually selecting the mtext objects.
    (setq vla_mtext (vlax-ename->vla-object (setq mymtext (car (entsel)))))
    (vla-put-LineSpacingFactor vla_mtext 0.5)
    Can this lisp be changed so it changes all mtext objects found in the drawing, or is there another way?
    Thanks
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,224
    Code:
    (defun C:test ( / acDoc scf cnt )
    	(setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
    	(setq scf 0.5)
    	(setq cnt 0)
    	(vlax-map-collection (vla-get-Block (vla-get-ActiveLayout acDoc))
    		(function
    			(lambda (x)
    				(and
    					(eq (vla-get-ObjectName x) "AcDbMText")
    					(eq :vlax-false (vla-get-Lock (vla-item (vla-get-Layers acDoc) (vla-get-Layer x))))
    					(vlax-property-available-p x 'LineSpacingFactor)
    					(setq cnt (1+ cnt))
    					(vla-put-LineSpacingFactor x scf)
    	(if (> cnt 0)
    		(alert (strcat "\nProceeded " (itoa cnt) " mtext objects! "))
    		(alert "\nNo mtext objects are found in this tab! ")
    );| defun |; (or (vlax-get-acad-object) (vl-load-com)) (princ)
    Or maybe just:
    Code:
    (defun C:test ( / scf SS i )
    	(princ "\nSelect mtexts to change their \"LineSpacingFactor\": ")
    	(setq scf 0.5)
    	(if (setq SS (ssget "_:L" (list (cons 0 "MTEXT"))))
    		(repeat (setq i (sslength SS))
    			(vla-put-LineSpacingFactor (vlax-ename->vla-object (ssname SS (setq i (1- i)))) scf)
    	(if SS (princ (strcat "\nProceeded " (itoa (sslength SS)) " mtext objects! ")))
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,418
    Another:
    Code:
    (defun c:mtlsp ( / i s )
        (if (setq s (ssget "_X" '((0 . "MTEXT") (-4 . "<>") (44 . 0.5))))
            (repeat (setq i (sslength s))
                (entmod (append (entget (ssname s (setq i (1- i)))) '((44 . 0.5))))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,042
    I can see the next question oh I want a different spacing
    Code:
    (defun c:mtlsp ( / i s rnum)
        (setq rnum (getreal "\nEnter spacing <Cr> = 0.5 "))
        (if (= rnum nil)(setq rnum 0.5))
        (if (setq s (ssget "_X" (list (cons 0 "MTEXT") (cons -4  "<>") (cons 44 rnum))))
                (entmod (append (entget (ssname s (setq i (1- i)))) (list (cons 44 rnum))))
  5. #5
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,224
    Quote Originally Posted by BIGAL View Post
    BIGAL - the Prophet
  6. #6
    Forum Newbie
    Manufacture
    Electrical Engineer
    Manufacture
    AutoCAD 2015
    Oct 2016
    Sweden
    2
    Smile Solved!
    Quote Originally Posted by Lee Mac View Post
    Another:
    Code:
    This code solved the problem perfectly, thanks again!!!
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,418
    You're most welcome
  1. Changing font and width factor of multiple text styles
    By sala in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Jul 2016, 08:21 am
  2. Replies: 1
    Last Post: 7th Jul 2015, 10:56 am
  3. Changing Font of Multiple MText
    By acad2012 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Jul 2012, 05:17 pm
  4. changing line space factor for existing text
    By Hickoz_bro in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Mar 2008, 01:46 pm
  5. Clicking into Model Space in viewport changing the zoom factor?
    By Match in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Jun 2007, 12:33 am
Tags for this Thread
