Hello everybody,
The following works with circle, line but not with lwpolyline, spline:
(defun C:RT ( / ent data )
(if (setq ent (car (entsel "\nSelect object to change its color")))
		(if (not (assoc 62 (setq data (entget ent))))
			(setq data (append (list (cons 62 1)) data))
			(setq data (subst (cons 62 1) (assoc 62 data) data))
		(entupd (cdr (assoc -1 (entmod data))))
Is there an easy fix for this?
Try this :-
(defun c:test ( / a b i)
 (if (setq a (ssget '((0 . "*line,circle,ellipse,point"))))
   (repeat (setq i (sslength a))
     (setq b (vlax-ename->vla-object (ssname a (setq i (1- i)))))
     (vla-put-color b 1)
Another:
(defun c:rt ( / e )
   (if (setq e (car (entsel)))
       (entmod (append (entget e) '((62 . 1))))
One more!
(defun C:RT ( / EOBJ )
(setq EOBJ (entsel "\nSelect object to change its color"))
(if EOBJ (vl-catch-all-apply 'vla-put-Color (list (vlax-ename->vla-object (car EOBJ)) 1)))
Edited by tombu
Updated to avoid error for a null argument Lee Mac pointed out.
Thanks guys, now I see the problem in my code:
must be:
(setq data (append data (list (cons 62 1))))
One more!
(if (setq EOBJ (vlax-ename->vla-object  (car (entsel "\nSelect object to change its color"))))
	(vl-catch-all-apply 'vla-put-Color (list EOBJ 1))
Careful - vlax-ename->vla-object will error for a null argument ;)
Fixed code above.
Thanks,
Thanks, now I know how its done with visual lisp.
